Old 29-03-2005, 04:16 PM   #1 (permalink)
whoopy_whale's Avatar
Default Overcoming administrator restrictions
I am accessing net from my college.Recently,our admin denied access to greeting card sites like 123greetings.com
Is it possible to bypass these restrictions by any means?
Plz help...
whoopy_whale is offline
Old 29-03-2005, 05:24 PM   #2 (permalink)
enoonmai's Avatar
The simplest way to overcome this is to go to this page:
http://www.space.net.au/~thomas/quickbrowse.html
and then use any of the anonymous browsing tools to bypass the restrictions in effect. If this doesn't work, I will let you know of another way. Lets try the simplest way out first.
Playing FEAR XP/LSW2
enoonmai is offline
Old 30-03-2005, 11:50 AM   #3 (permalink)
Thanx enoonmai,
It works pretty well with Guardster.
Plz tell me about the anonymizing browsing tools too.I tried to install one but couldn't finish bcoz it can be installed only from an admin account.
In just two days, tomorrow will be yesterday.
Old 30-03-2005, 12:05 PM   #4 (permalink)
enoonmai's Avatar
Well, unfortunately, installing programs may have been disabled for your account and since most anonymous browsing tools make changes to your browser in slight ways, like adding an extra menu item, etc. they may not install without administrator rights. I am yet to come across a program that allows a limited user to install it, but if I do come across one, I will let you know. Bypassing administrator software restriction policies without permission isn't particularly safe or correct. If this works, continue to use it. Why complicate things further, plus this way you dont really leave much of a trace or do anything that will get you into trouble.
enoonmai is offline
Old 30-03-2005, 03:10 PM   #5 (permalink)
I think you are right.After all I just want to access some blocked greetings sites and with your help,it's possible now.
Old 30-03-2005, 03:24 PM   #6 (permalink)
if you can consider http-tunneling as a anonymization tool then there is one which does not require for you to do any sort of installation. All it needs is JVM to be installed and it is available for free. Its called your-freedom (google it).
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 30-03-2005, 04:35 PM   #7 (permalink)
Your-Freedom is available here....
Old 30-03-2005, 04:35 PM   #8 (permalink)
try these sites also
http://idzap.com
http://behidden.com/
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 30-03-2005, 05:07 PM   #9 (permalink)
For some unknown reason,behidden.com doesn't seemed to be working.It was very slow,I just entered the URL and waited but the page never showed up.
idzap.com doesn't suit me.I registered for the free anonymous browsing service.When I tried to access 123greetings.com,I got the familiar message(the usual one)
Access Denied.
Access control configuration prevents your request from being allowed at this time. Please contact your service provider if you feel this is incorrect.
Generated Wed, 30 Mar 2005 11:32:51 GMT by dvbserver (squid/2.5.STABLE1)
The URL was modified as http://fr0.idzap.com/)d1(123greetings.com/)a1(WWSZU/http://123greetings.com
I guess that's the trouble.The name 123greetings.com is right there in the modified URL too.
Guardster is better.
The URL 123greetings.com is modified as http://proxy.guardster.com/cgi-bin/n...67732e636f6d2f
So it works perfect for me.Unlike some other services where the images are blocked,this one works with out any trouble(so far)
Old 31-03-2005, 09:12 AM   #10 (permalink)
well i too use behidden and it works..my guess is ur admin could have blocked access to the behidden site itself.since guardster works fine,u culd continue with it.but make sure ur admin doesn't know abt it
Old 31-03-2005, 11:40 AM   #11 (permalink)
godsownman's Avatar
I can access the site but my admin has blocked the content that is received from these sites.
@ Enoonmai can you please tell me the 2nd way to access this.I cant access " https:// " based sites which i need to access.
It opens all others except https:// sites
I cant access through the link you provided .
Please help .
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 31-03-2005, 12:20 PM   #12 (permalink)
enoonmai's Avatar
The second method is to use HTTP Tunneling with your-freedom, like icecoolz suggested. Download the program from here:
http://www.download.com/Your-Freedom...-10368502.html
and install it to bypass admin restrictions. Next, register at their site at:
http://www.your-freedom.net
and you will be able to bypass admin restrictions and browse secure HTTPS sites.
enoonmai is offline
