Old 29-03-2005, 04:15 PM   #1 (permalink)
Default How to convert RM songs to MP3
I have many songs in real media(rm) format..How do I convert them into MP3 format...PLease suggest some free software for the same purpose.
<<<<<<Rahul Khemka>>>>>>
khemkarahul is offline
Old 29-03-2005, 05:17 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Advanced MP3 WMA Recorder
get it here
google before u post
this was the first result
i used to use Streambox ripper for the same abt 6 yrs ago
dunno whether it still exists or not
Sourabh is offline
Old 29-03-2005, 05:52 PM   #3 (permalink)
pirates1323's Avatar
You can try boilsoft rm to mp3 converter.........http://boilsoft.com/download.html ..........hmmm..if u want its full version......then download its crack urself
pirates1323 is offline
Old 29-03-2005, 06:13 PM   #4 (permalink)
cool_dude_prav's Avatar
@Sourabh...
Streambox ripper still exists.. I tink it is in Ver.2 or so...
I believe it is the best...
As it can also be used to save streaming RM files onto the disk
Get it Here... The entire StreamBox suite...
Cheers!!!
] K8)8)L [
The Bloglines of an Angry Indian -
www.angry-indian.com
If only life were as easy as Ctrl+Z (undo) and F4/Ctrl+Y (redo)...
cool_dude_prav is offline
Old 29-03-2005, 09:04 PM   #5 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Hmm... did ya read the rules?
Anyway, even i will tell boilsoft RM to mp3 converter is the best and which i use and i recommend it... 8)
But, unfortunetly it's not free
But beware...boilsoft has two types of softwares which is almost the same, one is RM converter (which converts .rm/.ram to .avi/.mpeg etc...) and the other one is RM to mp3 converter which converts .rm/ram to .mp3 .
Or if u want to use a freeware:
download dBpowerAmp music converter from http://www.dbpoweramp.com/dmc.htm and download the real audio codecs from http://www.dbpoweramp.com/codec-central-ra.htm
drgrudge is offline
Old 31-03-2005, 02:25 AM   #6 (permalink)
friend,
I think the best ware that you might find over here is calld : -
Tinra
and you might also try : R7 CONVERTER
arnold is offline
Old 01-04-2005, 02:10 PM   #7 (permalink)
Thx..
- by soumya
- by Charley
