Old 29-03-2005, 01:54 PM   #1 (permalink)
Default help me with the config
i want to buy a new pc with the following config
AMD 64 3200+ (S939)
nForce 3 chipset Mobo (suggest a model)
1GB Ram (suggest a company)
Nvidia 6600GT (8x AGP)
160GB HDD (suggest a company)
Cabinet (please suggest one)
speakers (please suggest one)
DVD Writer (please suggest )
i am having 17" monitor already so I will not be buying a new one same is for
Keyboard and mouse.
please list the prices of teh components and also suggest any changes if required.
my budget is around 40k.
thanx in advance
harshagarwal is offline
Old 01-04-2005, 12:13 PM   #2 (permalink)
geek_rohit's Avatar
You config looks fine.
MSI K8N Neo2 mobo
For RAM get Kingston
Speakers-Creative, they are the ultimate. Get atleast the 5.1 set.
Maxtor for HDD
Any cabinet from a reputed company will do. Just ensure that there is a good scope of adding fans for better cooling
For prices www.npithub.com
SportZForumZ - We Know Your Game Better
http://www.sportzforumz.com
My Site & Blog
http://www.rohit-sharma.com
geek_rohit is offline
Old 01-04-2005, 03:40 PM   #3 (permalink)
Yep u can also opt for Giagbyte K8NS-939 for arnd 6-6.5k. Although not based on the nf3 chipset, i wud also recommend chking out the MSI RS480 mobo.
Get Transcend since it is know to be a better oc'er than the KVR.
HDD - Seagate
Cabinet - Get any generic cabby, but make sure that it has enough case fans or provisions to add in more. If u have moolah to spend get the Antec SLK1650 with 350W PSU for little less than 3k.
Speaker - Altec Lamsing 251 or VS3151 (Recommendations for the VS3151 by suave_guy )
DVD Writer - Benq 1620 Awesome writer for that price.
Also i'd suggest that you get the MSI RS480 board and a PCi-express 6600GT (priced same as the agp version) So that you wil be future safe so to speak.
www.techenclave.com Ecumenical Technology !
blade_runner is offline
Old 01-04-2005, 07:46 PM   #4 (permalink)
AMD 64 3200+ (S939) - 9800
nForce 3 chipset Mobo (suggest a model) -I think 9-12k(can be a little lower/higher,don't know that much)
1GB Ram (suggest a company) -Transcend/Kingston/Corsair(corsiar is expensive)
Nvidia 6600GT (8x AGP) -should be about 12-13k
160GB HDD (suggest a company) -Maxtor(ask for its stability/performance,in earlier digit sata performed not to good maybe,checkup, also western digital,samsung ,seagate)
Cabinet (please suggest one) -Any budget suited with 400watts ps and enuf space for fans etc
Consider the following by trying and asking others:
Altec Lansing 251 4-4.5k(even about 4800+ some parts)
Altec Lansing 5100 9-10k
Logitech x530 showroom price 8k
Artis x10 about 7k perhaps
Creative Inspire 5.1 IS NOT DECENT IN SOUND QUALITY
dvd rw should be for about 4.5-5k
You can also consider 754 socket as by the time you upgrade ,you would be doing the cpu+mb+vga all together,754 will be cheaper and at clock speeds amd 3400 is better fro games.
akshayt is offline
