Old 20-12-2007, 09:29 AM   #1 (permalink)
56561's Avatar
Smile RAM problem . please suggest
I have some problem in my ram . my pc is 1.5 yrs old and it has got DDR 1ram . so I called my pc vendor . they came and saw the problem and said the ram is got problem . Now they told me ' RAM CANNOT BE CURED . IT IS JUST USE AND THROW . SO YOU HAVE TO CHANGE IT '. now the problem is they again said > u better change the system like CPU , mobo , ram because now ddr1 is unavailable . so you need to chage the system . buy from us so we will give u some consession .
now what should I do? why ram cannot be cured ?
56561 is offline
Old 20-12-2007, 10:02 AM   #2 (permalink)
nach p's Avatar
Default Re: RAM problem . please suggest
ki$k on his a$$.
Mostly rams like Transcend has 3yrs warranty & kingston has 5yrs warrenty.
Btw make sure wid some one else tht ram is the prob.
If its checkout its warrenty.
If within warrenty u will get replacement.
If without warrenty den u have 2 buy new one.
And der is no big deal in getting ddr1 ram.
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 20-12-2007, 11:46 AM   #3 (permalink)
9437077259
go4saket's Avatar
DDR1 RAM is available in the market... Check you RAM with Memory checking utilities like Memtest86 to see if your RAM is actually bad or not. Never trust these hardware dealers. They are always in a see to f__k someones a_s
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 20-12-2007, 12:12 PM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
chk here for ddr1 price http://www.theitwares.com/ram/ram.htm
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 20-12-2007, 12:15 PM   #5 (permalink)
Deadman Walking
Batistabomb's Avatar
go for DDR1
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 21-12-2007, 03:07 PM   #6 (permalink)
56561's Avatar
but I want to ask you ppl that if a RAM becomes faulty then why we cannot make it bring around?
56561 is offline
Old 21-12-2007, 03:15 PM   #7 (permalink)
anand1's Avatar
We cannot repair it because the technology today is of large integration on a single chip and find the fault and then to repair it takes lot of cost. So one prefers more to buy new then to repair it. More over u will rarely find people having the Cip level knowledge to repair any of the borads.
Technology On The Fly
anand1 is offline
Power Problem, suggest me please... Ankeet Hardware Q&A 23 25-08-2007 08:17 PM
<Please Suggest> .dat to .avi without audio sync problem a_medico QnA (read only) 1 21-07-2007 02:43 PM
weird mouse problem- please suggest ~It_is_Andrew~ Hardware Q&A 12 21-07-2006 09:07 PM
Mouse Problem . help & suggest <> hellomotto Hardware Q&A 4 12-03-2006 08:38 PM
