Old 19-12-2007, 04:23 PM   #1 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Which is the better buy ?
I am going to buy a new laptop, with a mid high range of hardwares' power. Well I have short listed Dell Inspiron 1520 and the new XPS M1530. The config I decided to go over is given below :
C2D T7200 @ 2.00 GB, 800 MHz FSB, 2MB L2 Cache,
2GB 667MHz RAM,
nVidia GeForce 8600 GT with 256 MB onboard,
15.4" Glossy Widescreen
I can get this config at both Inspiron 1520 and XPS M1530, but I think the XPS has better looks.
So what to buy ?
debsuvra is offline
Old 19-12-2007, 04:53 PM   #2 (permalink)
Default Re: Which is the better buy ?
If both have same config then go for Dell.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 19-12-2007, 05:27 PM   #3 (permalink)
prasad_den's Avatar
^^ Both ARE dell....!!
@OP: I'd go for something that was cheaper.. simple..!!
prasad_den is offline
Old 19-12-2007, 09:54 PM   #4 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: Which is the better buy ?
Yeah both are from same company but they have some price differences.
@ Choto Cheeta, You are a great system recommender. Can u please review my query ?
debsuvra is offline
Old 19-12-2007, 11:45 PM   #5 (permalink)
j1n M@tt's Avatar
Thumbs up Re: Which is the better buy ?
It seems like Inspiron and XPS haf d same h/w and so d same performance.
XPS is new from Dell,may be it will be better than Inspiron......and XPS haf great looks.
My personal pick is XPS M1530.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
