Old 18-12-2007, 11:19 AM   #1 (permalink)
ayush_chh's Avatar
Default Strange Problem!!
hi guys!
i am facing a strange problem. i m getting a blue screen which tells someting of hardware faliure whenever i boot to windows XP...........first time i got this msg, i repaird windows.........but now i get this msg every time i try to boot.
i repair it each time and run it but the next time i shutdown and restart it the same problem arises.........what may be the problem??
i havenot installed any new harware to my PC nor i have a faulty RAM( i have checked).........
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 18-12-2007, 01:20 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Strange Problem!!
Most probably ..your hard disk has got bad sector.
Try to repair your XP.....that might help.
ravi_9793 is offline
Old 18-12-2007, 01:27 PM   #3 (permalink)
Burning Bright
anantkhaitan's Avatar
Ahh! XP and its BSOD(s)... Perhaps reinstalling is the only way
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 19-12-2007, 11:23 AM   #4 (permalink)
ayush_chh's Avatar
that is what i m doing every time to boot my PC
but what may be the raeson behind this............reinstalling is the last and final solution
Old 19-12-2007, 11:44 AM   #5 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
BSODs appear ONLY when there is either a problem with the Hardware or the Drivers. It's a Stop Error.
I'd suggest you to update all your drivers, unmodify your system files. (type sfc /scannow in Start->Run) and Install all the latest updates to Windows (after running sfc)
Windows doesn't BSOD unless your PC has the problem.
And can you post which file is mentioned in the BSOD? Some .dll/.sys file? (and the BSOD 'title' if you can).
If nothing else works, Repair Install XP and then do the above.
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 19-12-2007, 01:24 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
@[xubz] ..... has a great option ......
also try switching ur RAM modules ....... else try removing ur Graphic card & placing them again ......
or any other hardware which was recently installed ......
or any new drivers installed ......
... W H O T ...
ax3 is offline
Strange Problem amit2005 QnA (read only) 4 04-12-2006 10:32 PM
Strange XP Problem saurabh.sauron Software Q&A 11 23-09-2006 05:51 PM
Strange Problem With HDD tarey_g Hardware Q&A 12 06-06-2006 12:32 AM
Strange! very strange..!! Where is the Problem ? Ricky QnA (read only) 8 11-04-2005 04:14 PM
strange problem paul_007 QnA (read only) 8 28-02-2005 08:56 PM
