Old 16-12-2007, 05:49 PM   #1 (permalink)
Default How to remove W32.Almanahe.B worm
Hi all,
My NAV, 2005 detected C:/Windows/Linkinfo.dll file corrupted with W32.Almanahe.B!inf virus. It says Unable to repair the file. I have searched the removal method from NAV website. But while trying to edit the registry entries, I could not find the entry values mentioned in removal method. So unable to edit the registry etntries. Could any body tell me alternate way to remove the virus. Thanks in anticipation of quick help.
http://www.arunshakya.blogspot.com
Arun Kumar is offline
Old 18-12-2007, 10:40 PM   #2 (permalink)
Unhappy Re: How to remove W32.Almanahe.B worm
No response I desperately need the solution. Pleeeeeeeeeeease help me out.
Old 18-12-2007, 10:46 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: How to remove W32.Almanahe.B worm
Disable System restore and delete if NAV fails to heal it..
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 19-12-2007, 10:07 PM   #4 (permalink)
SivaChand
Try any antivirus like avast,bit defender... Try in safe mode deletion
kpmsivachand is offline
Old 19-12-2007, 11:11 PM   #5 (permalink)
nach p's Avatar
yup either use avg or nod
or use online scanning facility by avast ,kasparky etc
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 20-12-2007, 12:39 AM   #6 (permalink)
Tech.Masti's Avatar
Ya try some online scanning service.
Tech.Masti is offline
Old 21-12-2007, 08:10 PM   #7 (permalink)
Try Kaspersky 7 or NOD32
ico is offline
Old 21-12-2007, 08:32 PM   #8 (permalink)
-----ATi-----
nvidia's Avatar
Visit this place
Symantec
there is a detailed description of the virus and the process to remove it.
If it doesnt help then try
Google
http://twitter.com/akshayms
nvidia is offline
Old 21-12-2007, 09:14 PM   #9 (permalink)
Thanks a lot u all for ur advice.
nvidia8800: I had earlier tried the solution given there. But could not go further beyond these steps: -
Navigate to and delete the following entries:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{C111980 D-B372-44b4-8095-1B6060E8C647}\InprocServer32\"(Default)" = "C:\WINDOWS\AppPatch\deamon.dll"
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{C111980 D-B372-44b4-8095-1B6060E8C647}\ThreadingModel\"(Default)" = "Apartment"
HKEY_LOCAL_MACHINE\SOFTWARE\Miscrosoft\Windows\Cur rentVersion\ShellServiceObjectDelayLoad\"DL5" = "{C111980D-B372-44b4-8095-1B6060E8C647}"
Navigate to and delete the following subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\SynTPS
Exit the Registry Editor.
5. To find and stop the service
Click Start > Run.
Type services.msc, and then click OK.
Locate and select the service that was detected.
Click Action > Properties.
Click Stop.
Change Startup Type to Manual.
Click OK and close the Services window.
Restart the computer.
as I could not find such registry entries and also could not understand what services it is talking about. Any suggestions?
Old 21-12-2007, 09:24 PM   #10 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
hav u tried manually deleting the file?
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 23-12-2007, 04:47 PM   #11 (permalink)
zyberboy: Is it safe to delete the file. Path of file is C:/Windows/system32/linkinfo.dll
Can anybody tell me what the file is about. Will deleting it makes any problem in working of Windows as it seems system file.
Old 23-12-2007, 06:28 PM   #12 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
try Ultimate Boot CD for Windows. its the best solution.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 25-12-2007, 05:29 PM   #13 (permalink)
Distinguished Member
anandk's Avatar
The legit MS linkinfo.dll resides in the System32 folder. Yours is in the Windows folder. Go ahead and delete it. Use Winpatrol or Delete Doctor to delete it on reboot. Run CCleaner after that to clear the Reg entries.
If you want to re-check, rt-click on this files properties and / or get it scanned at jotti.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 25-12-2007, 06:40 PM   #14 (permalink)
Thanks a lot anandk and others for suggesting me solutions.
Anandk: Thanks. It worked. I had used DeleteDoctor and CCleaner to get rid of file.
New Yahoo IM worm!!! naveen_reloaded Random News 6 26-12-2008 01:40 AM
WORM SPREAD - Skype worm jumps to ICQ, MSN techtronic Technology News 1 25-05-2007 03:19 PM
WORM BEWARE : New Worm Targets Portable Memory Drives techtronic Technology News 1 07-05-2007 05:18 PM
blaster worm zuhaib QnA (read only) 6 29-01-2005 11:56 PM
worm!!!! Shajahan QnA (read only) 2 30-11-2004 12:05 PM
