Old 15-12-2007, 07:13 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Question domain registered .... issues...
i have registered a domain for myself .. thru rediff ... say XYZ.com
now i used google apps (basic edition) for creating a mail ID for myself with the domain ...
iinfi@XYZ.com
this mail ID works fine ... and i m even able to redirect the page
mail.XYZ.com to the google apps page .... but the issue is the name google appears on the URL ... and not "mail.XYZ.com/blahblah"
again i m unable to redirect the the main page http:// XYZ.com OR http:// www.XYZ.com to any specific page i want to as rediff asks for a numeric IP address .. i dont have one ...
can i not redirect www.XYZ.com to any other page ???
plz help
mekalodu
iinfi is offline
Old 15-12-2007, 07:28 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: domain registered .... issues...
If you have hosting with rediff aswell, simply upload HTML page redirecting to the webpage
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 15-12-2007, 07:32 PM   #3 (permalink)
mekalodu
iinfi's Avatar
i dont have hosting with rediff .... i want the default page www.XYZ.com to be redirected to the google apps page and it doesnt happen ....
because rediff allows only a numeric IP to be entered in the default page www.XYZ.com .. is there a workaround ..
mekalodu
iinfi is offline
Old 15-12-2007, 07:40 PM   #4 (permalink)
Host4Cheap.org
Can you post a screenshot of Domain Panel, so we can understand it more clearly You will be most likely needing thrird part DNS Management
Old 15-12-2007, 08:24 PM   #5 (permalink)
mekalodu
iinfi's Avatar
Question Re: domain registered .... issues...
here you go ... 2 snap snapshots .... the IP address is the default on which was given by rediff ... there is no place to enter any other address ....
it doesnt allow me to delete the www alias and use it as a CNAME alias and point to where i want ...
mekalodu
iinfi is offline
Old 15-12-2007, 08:27 PM   #6 (permalink)
Host4Cheap.org
Interting, try to use thrid Party DNS Service like
http://www.everydns.net or editdns.net
Old 15-12-2007, 08:42 PM   #7 (permalink)
mekalodu
iinfi's Avatar
pardon my ignorance .... is there a way to change the domain registrar ??
to one who gives me more options ?? i think i v been a fool to use rediff ...
what do these http://www.everydns.net or editdns.net do??
mekalodu
iinfi is offline
Old 15-12-2007, 08:47 PM   #8 (permalink)
Host4Cheap.org
You can transfer the domain after 60 days of registration. Everydns.net and editdns.net both offer third party DNS Management for free
Old 15-12-2007, 09:48 PM   #9 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Nice links. Thanks a lot
गीक होना माँगता
victor_rambo is offline
Old 15-12-2007, 11:49 PM   #10 (permalink)
mekalodu
iinfi's Avatar
i m not an expert in this .... i m completely confused ...
Note:
Make sure that your domain points to ns1.everydns.net, ns2.everydns.net, ns3.everydns.net, and ns4.everydns.net in your registrar's whois database. Without that, none of your records will resolve properly.
what does the above mean ??
do i have to change the nameserver settings ??
this is what is the current setting in my rediff control panel
Existing Name Servers
Primary Name Server
ns.rediffmailpro.com
Secondary Name Server
ns2.rediffmailpro.com
mekalodu
iinfi is offline
Old 16-12-2007, 08:47 AM   #11 (permalink)
eWebGuru
ahref's Avatar
yes, you have to change NS entries and replace rediff nameserver with everydns nameserver, if you want to use everydns, DNS services
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Old 16-12-2007, 09:15 AM   #12 (permalink)
Host4Cheap.org
Yes, change nameservers to Editdns.net or everydns.net. Suggest you to use Editdns.net since i use it aswell. I am not sure of Everydns.net panel but i have heard good feedback about it aswell
Old 16-12-2007, 09:36 AM   #13 (permalink)
TechTin.com
ravi_9793's Avatar
U can redirect..by editing .htaccess file in ur hosting main folder (public_html) hosting.
Add this code in .htaccess file
Options +FollowSymLinks
RewriteEngine on
RewriteCond %{HTTP_HOST} !^www\.yoursite\.com
RewriteRule ^(.*)$ http://www.whost.in/$1 [L,R=301]
Replace www.whost.in with the site where U want to redirect.
ravi_9793 is offline
Old 16-12-2007, 11:17 AM   #14 (permalink)
Host4Cheap.org
Ravi he said, he doesnt have hosting bro
Old 16-12-2007, 12:42 PM   #15 (permalink)
TechTin.com
ravi_9793's Avatar
Ok..than I may have missed that line.
No problem brother...if U dont have hosting..than take from me free..absolute free. I will give U 5 MB free hosting..only to redirect your domain name.Please dont use to host any webpage
Old 16-12-2007, 06:10 PM   #16 (permalink)
mekalodu
iinfi's Avatar
well, i did something ....
google apps suggested that, to got the start page of google apps, my CNAME alias should be www and it should point to ghs.google.com
but rediff does not allow www to be a CNAME as it is already a A Record and that cannot be changed!!
what i did was ... chk the IP address of ghs.google.com... found it to be 66.249.81.121.
now i type this IP in the A Record. .... it still doesnt work !! it takes me to the site underconstruction page ... which has a different IP address !!
mekalodu
iinfi is offline
Old 17-12-2007, 08:37 AM   #17 (permalink)
TechTin.com
ravi_9793's Avatar
wait DNS updation takes time.
But I am not sure, it will or not .
Old 17-12-2007, 05:06 PM   #18 (permalink)
Host4Cheap.org
IT will not work AFAIK. You will have to use DNS Management from third party sites as said earlier
Old 23-12-2007, 01:11 AM   #19 (permalink)
mekalodu
iinfi's Avatar
follks .. its working now jus as i want it to ... thanks ..
i typed 66.249.81.121 in the ARECORD n it worked after 72 odd hrs ..
thanks a lot for your support
mekalodu
iinfi is offline
Old 23-12-2007, 09:09 AM   #20 (permalink)
Host4Cheap.org
Good to know
Website to accept domain name payments and send domain names Charley QnA (read only) 3 06-10-2007 06:45 PM
change the 'registered to' iMav QnA (read only) 14 11-09-2006 11:12 AM
registered a domain. now what next? nix QnA (read only) 9 28-07-2005 11:37 AM
Changing the Registered Owner aman_agrawal QnA (read only) 3 03-06-2005 07:56 PM
