Old 28-03-2005, 05:10 PM   #1 (permalink)
jay4u's Avatar
Default Help needed... searching images on HDD
I wanted to search images in my computer and categorised them based on their dimensions. Like i would like to search all images which are 800 x 800 pixels.....
If anyone knows such software available then plz post the links......
Note : This is the second time i am posting this message. I didn't got any replys earlier.
Passwords are like underwear... Change them often...
jay4u is offline
Old 28-03-2005, 07:29 PM   #2 (permalink)
Arrange images by size . hope this will solve it.
some time the image width and height may be small but not the file size.
vijaythefool is offline
Old 28-03-2005, 08:26 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Hmm...Get picasa 2
http://www.picasa.com/download/index.php
I think it will detect ur images/pictures in your HDD and classify according to the Date when it was created...
And now u can get the pic. which are 800*800 pixel in size.
P.S : I dont know if picasa classifies according to image size..., it detects the images for you...
drgrudge is offline
Old 28-03-2005, 08:26 PM   #4 (permalink)
Try the new google search & see if some plugin is available for ur needs
I came.. I saw.. I read.. I learnt..
WISEN UP !!
imported_rusty is offline
Old 28-03-2005, 11:49 PM   #5 (permalink)
jay4u's Avatar
Default Tried harder to find but in vain...........
I tried many places on the internet... download.com ... snapfiles.com...... google it... msn search.... but still i am not able to find it..........
Well my Hard drive holds more than 2 lakh images ( really ) ...... which i want to categorise.... as per their contents.... and i want to filter out images that can be used as wallpapers..... Hence i am searching this utility...... Sorting images with size is of no use...I badly need a software which sorts by image dimensions...........
jay4u is offline
Old 29-03-2005, 01:20 AM   #6 (permalink)
Hmm..... i never heard of such engine
Life sucks loosers dry,if u wanna f#@k with the eagles u have to learn to fly !!
beaditya is offline
Old 29-03-2005, 09:06 PM   #7 (permalink)
enoonmai's Avatar
ACDSee can sort images based on their size, I am not sure if they support image 'dimensions' as a search criteria, but they definitely do support image filesize as a filter. You can use to specify an upper bound to the file size, create a filter and use that to sort your images out. Maybe the ACDSee PowerPack supports this functionality. Try the software out here:
http://www.acdsystems.com/English/Pr...oads/index.htm
Playing FEAR XP/LSW2
enoonmai is offline
