Old 14-12-2007, 12:18 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default make web link ! ! !
i have abt 55 web links on a notepad .... wanna convert them 2 valid html links & work on a webpage ....
in dreamweaver, simply coping them on 2 a new pg doesnt work .... & selecting each link & clinking on "make link" takes time .......
how 2 i convert them as WORKING links ? any faster way ....
... W H O T ...
ax3 is offline
Old 14-12-2007, 12:34 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: make web link ! ! !
How are they written in the notepad file?
Can you plz post one or two from it?
गीक होना माँगता
victor_rambo is offline
Old 14-12-2007, 12:38 PM   #3 (permalink)
ax3
ax3's Avatar
just copied from sites ...... some wallpaper links .......
... W H O T ...
ax3 is offline
Old 14-12-2007, 12:39 PM   #4 (permalink)
हॉर्न ओके प्लीज़
Ok, but still, can you just put a couple of links here, so that I can see how they are.
गीक होना माँगता
Old 14-12-2007, 12:44 PM   #5 (permalink)
ax3
ax3's Avatar
http://www.bestofwallpapers.com/img-...fe-08-1862.htm
http://www.bestofwallpapers.com/img-...fe-04-1858.htm
http://www.bestofwallpapers.com/img-...loria-1936.htm
http://www.bestofwallpapers.com/img-hurcules-1928.htm
now try with these ........
... W H O T ...
ax3 is offline
Old 14-12-2007, 12:48 PM   #6 (permalink)
हॉर्न ओके प्लीज़
ooh.......thats will consume pretty much time with make link function.
गीक होना माँगता
Old 14-12-2007, 12:51 PM   #7 (permalink)
din
Tribal Boy
din's Avatar
@ax3
I have a solution This may sound funny lol
Copy all 55 links to any forum. Just the URLS. When you post or take review you can see the forum has addedm them as link but not with <a href => tag but with [url] tag
Now, open in any text editor, replace the url (find and replace - just one click) tag by a href tag.
Hope that works !!
LOL
Even more easy way !!
Post all url here. They will get converted to links auto. Save this page, open it in DW, copy all links
Simple isn't it ?
din is offline
Old 14-12-2007, 01:33 PM   #8 (permalink)
ax3
ax3's Avatar
@din ..... cool frd ........ u got it ........
bt was looking 4 a solution in dreamweaver ...... design & code gurus, any ans ?
... W H O T ...
ax3 is offline
Old 14-12-2007, 03:02 PM   #9 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Paste it in MS word and save as a webpage If it doest make a link, at the end of link, press return
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 14-12-2007, 03:18 PM   #10 (permalink)
din
Tribal Boy
din's Avatar
Hmm, I am not sure why the solution is not ok for you. The solution I mentioned works in Dreamweaver as well.
Once you get the code, you can copy paste in Dreamweaver isn't it ? (code view, not design view) Isn't it simple ? Any problems in doing so ?
Sorry if I didn't understand your requirement.
Or just copy paste the 55 links here, I will send the html in a minute.
Sometimes MS Word add unwanted code in HTML.
Dreamweaver code is always clean and pure HTML.
din is offline
Old 14-12-2007, 03:29 PM   #11 (permalink)
हॉर्न ओके प्लीज़
Just check if there is any options such as 'Automatically parse links'.
गीक होना माँगता
Old 14-12-2007, 04:19 PM   #12 (permalink)
ax3
ax3's Avatar
@rohan_shenoy ...... cannot find ur option ..... where is it ?
@din ..... bt everytime i will have 2 go online & on forum .... 4 this thing ....
something must b in dreamweaver as its made 4 it .......
... W H O T ...
ax3 is offline
Old 14-12-2007, 04:35 PM   #13 (permalink)
din
Tribal Boy
din's Avatar
Oh, I am sorry, I thought it is a single case.
din is offline
Old 14-12-2007, 05:30 PM   #14 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Here , i have attached a Program to do this .
The usage is:
ParseLinks <Filename>
By default:
1) The filename is "links.txt" if you don't provide any name
2) Outputs to the console
3) Outputs to the file "output.html"
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 14-12-2007, 05:56 PM   #15 (permalink)
ax3
ax3's Avatar
@Zeeshan Quireshi .... will check it out ........ thanx ......
... W H O T ...
ax3 is offline
Old 14-12-2007, 06:24 PM   #16 (permalink)
Host4Cheap.org
Thats correct, but thats the simplest methodi could think of , because Word is something which is available on almost PC for free and users are comfortable with it
Short URL Link jacob_901 Software Q&A 3 07-09-2007 05:19 PM
How to link VB.NET with SQL SERVER ? prasad_spy23 QnA (read only) 2 05-09-2007 03:21 PM
how make make anyone(unregistered users) post on my blog? kerthivasan QnA (read only) 5 23-07-2007 09:18 PM
