I'm really sorry friends if this is a repost. I did find similiar threads about the same just like the one mentioned here
video cutting applications
I have some couple of AVI files which I want to edit! From the search I did in the forums I came across couple of softwares mentioned in some of the threads! In one of the forums suggestion was HJ Split and the other one was Video Splitter. I tried couple of other softwares also! But the problem with couple of those softwares is after I split the file the output file isnt as good! Mostly the quality of the video is getting affected in the output as compared to the source file!
Most of the threads suggest Virtual Dub but I think that will split according to the size rather than where we want to split at a particular frame!
I just want to delete or edit some scenes in the movie so that I can watch the movie with my parents. I hope someone can help me on this ! No rencoding!
