Old 28-03-2005, 12:23 PM   #1 (permalink)
ashfahan's Avatar
Default advance system optemizer
I USED ADVANCE SYSTEM OPTEMIZER DEMO AND IT F***ED MY COMPUTER.
THANKS TO SYSTEM RESTORE I GOT ALL THING BACK.(I USED REG FIX FROM THE SOFTEWARE).
NOW I DONT GET 'SEND TO' ON RIGHT CLICK.
AND ALSO ON THE FOLDER ...\SEND TO THERE IS NO FLOPPY DISK ICON.
HELP.
ashfahan is offline
Old 28-03-2005, 12:54 PM   #2 (permalink)
swatkat's Avatar
Which OS you are using?
If it's Win98, go to Windows and create a Folder named SendTo.
If it's WinXP, then go to DriveName:\Documents And Settings\UserName\ and here create a Folder named SendTo.
Above, DriveName is where XP is installed and UserName is your user name.
And, go into the SendTo folder, and then put the ShortCuts of the applications and drives, here in this Folder, that you want in SendTo in the Right-Click menu.
And, if you have the SendTo folder but not shortcut icons inside it, then simply add Shortcuts.
http://swatrant.blogspot.com/
swatkat is offline
Old 29-03-2005, 05:45 AM   #3 (permalink)
Fresh Stock Since 2005
the solution by swatkat is not gonna help............... Read below
khattam_ is offline
Old 29-03-2005, 05:46 AM   #4 (permalink)
THIS WON'T HELP!!
I'm sure the SENDTO folder is intact with all the shortcut files in it.............................
Problem is with the Registry. Gone thru this B4 but i needed to Repair XP to get it back...............
@ashfahan
And by the way, the program is called "Advanced System Optimizer". And which version are you using?? I'm using the app for more than a YEAR and who knows better.............
However, i don't have a solution for u now other than repairing XP. I will fing\d a sloution for you or just help you to repair XP.............. But Laterz...... Wait for a few days............
khattam_ is offline
Old 29-03-2005, 10:01 AM   #5 (permalink)
NikhilVerma's Avatar
Advanced System Optimizer should be used carefully and by the people wo know what they are doing...
I think it corrupted your registry...
But to remove the send to .. Just searc the registry for the string your are searching and delete te key wich contains it...
AGAIN BEFORE REGISTRY EDITING, CREAT A BACKUP OF IT!!
NikhilVerma is offline
Old 29-03-2005, 09:14 PM   #6 (permalink)
I dont think he wants to remove SendTo but wants to bring it back...........
khattam_ is offline
Old 30-03-2005, 02:10 AM   #7 (permalink)
Well I thought Advanced System Optimizer was a great program!I certainly have no complaints against it!
Show me a sane man and I will cure him for you.
LayZ is offline
Old 30-03-2005, 05:14 AM   #8 (permalink)
http://www.dougknox.com/xp/scripts_d...dtodesktop.htm
might just help. Try it out...........
http://www.gabrieleponti.com/downloads/sendtotoys.exe
Might also help.................
khattam_ is offline
Old 31-03-2005, 06:53 PM   #9 (permalink)
Distinguished Member
anandk's Avatar
Default try correcting with tune-up utilities !
aso is great, but yeah, it can screw up the systme if not used carefully. try correcting your problems like missing icons or links, etc with tune-up utilities. next time use ace utilities. its SAFE !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
