Old 27-03-2005, 11:08 PM   #1 (permalink)
 MacManiac
jamesbond007's Avatar
Default Bad Clusters
My harddisk has developed bad clusters, which has considerably reduced the speed of my computer. I know that bad clusters cannot be removed, but is there any software which can mark the Bad Sectors and seperate them out so that they are not used by the programs on my PC
jamesbond007 is offline
Old 28-03-2005, 03:23 AM   #2 (permalink)
sms_solver's Avatar
use scandisk to mark bad sectors. if bad sectors are localized then make partitions and do not use the partition that has bad sectors
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 28-03-2005, 11:04 PM   #3 (permalink)
 MacManiac
Yes I did use scandisk, but the prob is that the bad clusters are at irregular places and if I go on to create partitions leaving the bad clusters , I would end up creating atleast 100 partitions!!!!!!
Old 28-03-2005, 11:43 PM   #4 (permalink)
pirates1323's Avatar
Default Re: Bad Clusters
use scan disk in through mode..........
pirates1323 is offline
Old 29-03-2005, 12:04 AM   #5 (permalink)
if i aint mistaken , bad sectors can also be shown , because of corrupt data or fat . like the time i had first quater of my disk brand new 120gb showing up as bad sector . just took the manufactureres disk utilities and ran a couple of test and then bad sectors were gone and hdd is fine now .
i would suggest u take a backup of all ur data and then run the manufactureres utilies to test the hdd . usually there are two modes , one is non-destructive and other destructive . if u have too much info and cant backup , run the non-destructive tests and recovery of bad sectors , else after backing up run write zeros to drive .
most cases formatting disk again will improve its condition . plus physically remove the disk and clean it of dust , so as to reduce the temp of hdd too
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 29-03-2005, 12:31 AM   #6 (permalink)
Use spinrite. It will mark the bad sectors and also try and move the data from the badsectors to unallocated spce. Secondly this should solve your problem of partitions as data will not allocated on the bad sector.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 01-06-2005, 05:22 PM   #7 (permalink)
my 6 months old samsung 80 gb disk is showing badf sectors.........can i replace it????????its warranty ends in 2007
magnet is offline
Old 02-06-2005, 05:24 PM   #8 (permalink)
Just Do It
But if it detected as BAD then the hard disk will be of no use if its at different places on the drive .......
Charley is offline
Old 02-06-2005, 05:37 PM   #9 (permalink)
Offcourse, Man. Otherwise why is that warranty for? :roll:
And its better if u ask ur vendor this same question....
sumitava_b is offline
Old 02-06-2005, 05:50 PM   #10 (permalink)
Any how, magnet, why did you double post it?
http://www.thinkdigit.com/forum/viewtopic.php?t=21942
Old 02-06-2005, 07:28 PM   #11 (permalink)
mr sumit i posted this question ard a day or 2 bak....no one answered and i was thinking to go to the place this sat.....its urgent and since no one was answering...i posted a topic......so atlest i can get 1 reply
magnet is offline
Old 03-06-2005, 09:13 AM   #12 (permalink)
Its okay, magnet.
How ever, have u talked to ur vendor about the replacement?
Old 03-06-2005, 11:28 AM   #13 (permalink)
most probably, if u r going to use the utility which comes with the drive, it's gonna scan, mark and hide ur bad sectors. Doesnt mean the drive is physically ok. but still u can use it with no fear of losing data. But if the bad clusters seems to be incerasing in number, u must back up and consider trashing ur drive for a new one..
Rajeev V Nair
premrajeev is offline
Old 03-06-2005, 03:33 PM   #14 (permalink)
my vendor is an idiot.....i wont go again there.....i deal directly with the service centre guy...i hopely will go coming saturday.....ill calll a day bak.......
they check disk probs only at saturday...ill let u guys know
magnet is offline
Old 03-06-2005, 06:45 PM   #15 (permalink)
Dipen01's Avatar
hey ...
dont worry..
new smasung HDD comes with 5 yrs warranty... i got my 40 GB PATA in early 2001... before a week..it just crashed..and after restarting...HDD wasnt being detected and there was a noise coming from it...
i just shown it to Service Centre..they took it (No Bill , No name)..and i got a new 40 GB in 3 days...
to my surprise it is a slimmer one ( yeah was sad as lost my good collection)...
so do just one thing show it to proper service centre...
Cheers..
Dipen
I love walking in Rain ,because no-one knows i am Crying
Dipen01 is offline
Old 03-06-2005, 09:50 PM   #16 (permalink)
dipen wht the service guy told u abt the prob???.......becoz i also faced same prob.........but directly checking the pins...1 pin was a 1-2mm inside...and he told pin is damage....on wall there was a big samsung banner which told pin damages r xcluded frm warranty...he took 750 bucks to giv me a brand new 80gb disk....
magnet is offline
Old 04-06-2005, 09:48 PM   #17 (permalink)
Dipen01's Avatar
hey there...
Actualy i didnt met the service guy in person...there was a lady assistant (clerk)..who used to take HDD , write serial nos. and give us reciept..
so i gave her HDD...i told her that my HDD is being detected and making noise..(though she was not interested)... then she told me to enquire after 2 days..
i did on 3rd day..and she said..my HDD is ready...when i asked her what was the prob.. she said she had no idea...
BTW who cares.. i got the new slim piece... and yeah i think that these guys dont replace HDD if got physical damage...i gues.. am not sure.. but will suggest u too check out..
Cheers..
Dipen
Dipen01 is offline
Old 06-06-2005, 11:34 AM   #18 (permalink)
hey warrenty services of both Seagate and samsung are good. Samsung's replacement is faster -Seagate will take around a week if needs repacement..
But who will pay for the data which is lost ????
For most of us, backing up 80 gb's of data is a huge task..and data lost will be more valuable than the cost of hdd..
Rajeev V Nair
Old 06-06-2005, 04:59 PM   #19 (permalink)
Dipen01's Avatar
UR rite buddy... what abt backup..?? this happened to me third time..once i was partitioning and there was power faliure.. all data lost.. cant help..even recovery softs were unable to recover anything...
thats why am planning to buy DVD-RW so atleast i can back up imp collection....
anywys...
Cheers..
Dipen
Dipen01 is offline
Old 06-06-2005, 06:35 PM   #20 (permalink)
Just Do It
Wrong I got it within 3 days, when my disk busted.
Charley is offline
Old 06-06-2005, 08:31 PM   #21 (permalink)
actually it may tak a single day also.......... they check it on the day when there engineer is present.......btw this saturday ill mak the visit to the place......btw has anyone got a new disk......when bad sectors were found on it????nyone
magnet is offline
Old 08-06-2005, 01:29 PM   #22 (permalink)
ok , i got two replacements from seagate after a week or so..must have improved their service...or just by chance it got delayed..
Rajeev V Nair
Old 09-06-2005, 03:05 PM   #23 (permalink)
Just Do It
Delayed only.....
Charley is offline
