Old 27-03-2005, 09:27 PM   #1 (permalink)
Default Dial Up connection goes dead within a minute
I have a Tata Indicom wireless phone and recently my internet connection has started going dead within a minute. I have those two computer monitors at the bottom right but no traffic passes.
What happened was that my registry got corrupted and registry checker replaced my registry with a half a yr old one. so i reformatted my comp and them this problem came up
I use windows 98 and I.E 6.
Any ideas?
Thnx
Karan
P.S. I posted this from a cybercafe so i wont be able to reply to your posts immediately.
Karan
¦[ F| ¦¯< F| |\| is offline
Old 27-03-2005, 11:18 PM   #2 (permalink)
hafees's Avatar
can u access any webpage? if no web page is accessible then there may be some problem with the protocol. (Make sure that u use the correct phone model & installation is correct)
check TCP/IP is installed and Type of dialup server is selected as PPP: Windows 95/98 is selected. not SLIP for UNIX. (Right click on dialup connection and then click properties)
hafees is offline
Old 28-03-2005, 12:25 AM   #3 (permalink)
anurag_online
Posts: n/a
Default Try
Reinstall the modem driver. i am sure the problem will be solved.... my frnd faced similar prob with reliance wireless phone..
Old 28-03-2005, 09:47 AM   #4 (permalink)
ashisharya's Avatar
Why dont u go for BroadBand? It will give u no disconnection, high speed and always-on connection.
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 28-03-2005, 11:10 AM   #5 (permalink)
mekalodu
iinfi's Avatar
if you are using LSP-340E phone u r bound to have frequent problems with your net ....
if there is no continusous data transfer then the line will go dead after some time .. after giving a few beeps ....
to solve this problem keep downloading something in the background ......... or stream some music online (go for something which eats up less bandwidth )
this is like saying ... "if you have a leakage in your house .... buy a new one .... lol "
mekalodu
iinfi is offline
Old 28-03-2005, 11:31 AM   #6 (permalink)
anurag_online
Posts: n/a
I completly agree with you iinfi CDMA conenction rocks and we dont have to pay heavily for per MB either.... I am using reliance 1500 plan... it is rocking on its best...
Old 29-03-2005, 01:50 PM   #7 (permalink)
enoonmai's Avatar
If you've fiddled with your registry settings, then the chances are that a serious corruption/conflict with the new copy is causing all your problems. Follow the instructions on this page to fix WinSock on your computer and then try reconnecting.
http://support.wadsnet.com/winsock/winsock98.asp
If that doesn't work, be prepared to back up all your data and do a clean reinstall of Windows 98.
Playing FEAR XP/LSW2
enoonmai is offline
Old 29-03-2005, 03:03 PM   #8 (permalink)
mekalodu
iinfi's Avatar
¦[ F| ¦¯< F| |\| did u follow what i had told u ???
i also had the same problem and got it solved by the way i have explained ....
first of all it sud b a LSP 340 E connection ..... for it to work the way i said
enonmai ... i respect ur brains ... but i dont think thats a registry problem ....
mekalodu
iinfi is offline
Old 29-03-2005, 05:12 PM   #9 (permalink)
first infii, the connection goes dead while i am accesing something like loading a webpage etc. maybe i can keep ragna on in the bakgrnd it might help
yes my homepage and other sites do get loaded
since i reformatted my comp so i had to reinstall my modem driver and everything else
I think its just a problem with Tata indicom coz their service just isnt that gr8
thnx for the advice
karan
Karan
Old 29-03-2005, 08:47 PM   #10 (permalink)
mekalodu
iinfi's Avatar
i have friends virtually in every part of mumbai ....
all say tata indicom connection rocks ....
i believe urs is a LSP-340 E phone ...
mekalodu
iinfi is offline
Old 30-03-2005, 03:26 PM   #11 (permalink)
the problem was that dns had to be disabled.
as for the service iinfi i do not like a connection which disconnects the moment u stop using it.
Their customer helpline is also a pain try using it.
nway
thnx for the adv
karan
Karan
Old 30-03-2005, 03:54 PM   #12 (permalink)
mekalodu
iinfi's Avatar
the phone itself is made that way .... i dont think the cust service can help u ...
try searching LG website and write to LG company and ask them abt it .... they mite b able to help you .....
mekalodu
iinfi is offline
Old 30-03-2005, 04:17 PM   #13 (permalink)
mekalodu
iinfi's Avatar
http://www.rimweb.com/forums/lofiver...x.php/f28.html
goto this site ... its a reliance forum ... many have similar probs and have posted their opinions .... same will apply yo ur tata fone ... try it
good luck
mekalodu
iinfi is offline
Old 31-03-2005, 09:32 PM   #14 (permalink)
The Only Solution is
Go For a Broad Band
The World is so going faster that a dailup cannot serve Future
Geek4u is offline
