Old 21-08-2004, 02:10 PM   #1 (permalink)
Default Dialup menu comming again and again???
My dear friends
I have a VSNL Dialup internet ..!@!
i m useing WINXP Pro
I m intall and scan with Norton Anti Pro 2004 with latest Patern Defination..!!
ANd Ad-ware With Latest Defination..!!
and SpyBot and Trojen remover.>!!
Trojen Hunter...!!
and i remove all problemetic files..!!
Problem is same..!!
any more setting or software requred...!!
Thanks
Have A Nice Day....!!
pr@k@sh is offline
Old 21-08-2004, 02:50 PM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
What is the problem btw ...????
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 21-08-2004, 05:26 PM   #3 (permalink)
read the topic of the post,batty
btw pr@k@sh there is no trojan on ur comp!!
all u r suffering from is the autodialing of win xp!!
i think u should change this setting
internet explorer>tools>internet options>connections>never dial a connection!!
hope this helps
silly_kash is offline
Old 21-08-2004, 08:09 PM   #4 (permalink)
Thanks My Dear friends
But i do that setting first and then scan with all this software..!!
but still problem ..!!
100% still torjan or spy in my pc..!!
how can i remove that ..!!
Thanks Dear
pr@k@sh is offline
Old 21-08-2004, 09:30 PM   #5 (permalink)
i have the same software config like u Prakash, with SP2,
but i'nt getting any problems likeu !!
.........my PC is Phully Computerized !!!!!!!! www.pankajkale.tk
http://www.freewebs.com/pankyprk/colorbarsmallp.jpg
pankyprk is offline
Old 21-08-2004, 11:32 PM   #6 (permalink)
Please post your HijackThis Logfile for better assesment of your problem.
Old 22-08-2004, 10:59 AM   #7 (permalink)
my friend had the same problem...it looks like a trojan at work, try kaspersky antivirus...sure 2 solve ur problem.
prankzter is offline
Old 22-08-2004, 03:35 PM   #8 (permalink)
try this setting!!
controlpanel>network connections>advanced(near file,edit,view etc)
dialup preferences>autodial(uncheck the box which says use this location for autodialing)
this should solve the problem!! even i had this autodialing thing bugginf me!!got rid of it by this!!
We are what and where we are because we have first imagined it...
--Donald Curtis
Old 22-08-2004, 10:47 PM   #9 (permalink)
Thanks silly_kash u realy solve my proble..!!
Thanks Again..!!
pr@k@sh is offline
Old 23-08-2004, 09:40 AM   #10 (permalink)
ooh yep buddy
that's what digit forum is made for!!
share whatever you know or ask what you want to know!!!
--Donald Curtis
