Old 11-12-2007, 02:08 AM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default Tri-Band Night UL
guys is mtnl tri-band night UL plan without caps or do they have some cap also is there any un-capped night UL plan?
(2 mbps conx)
http://beingmanan.com
iMav is offline
Old 17-12-2007, 04:04 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: Tri-Band Night UL
kya ?
with & without cap ?
... W H O T ...
ax3 is offline
Old 09-03-2008, 11:35 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
^^ wat u wanna ask exactly ?? Wats "CAP"
I hv recently upgraded from TRIBAND DSL 499 to DSL 849 Night UL of MTNL and If u mean that CAP=hidden settings or taxes or restrictions (wich are written in fine print) then there is nothing like that.
If u follow wat MTNL says "To disconnect and reconnect at 00.00 Hrs and again at 08.00 Hrs to avail night UL options then u are on right track
I hv had no problems with tat since a month i hv upgraded. as they do not charge u a single Mb in this UL period.
But, if u are asking abt the connection speed (that being 2 Mbps) at night, then it actually depends on ur MTNL location, as some areas have lesser speeds compared to other ISP locations of MTNL. bcoz if u read wat the plan says exactly, it reads MTNL TRIBAND DSL 849 Night UL=256 kbps/ upto 2 Mbps read the "upto" word.. so its not exactly that u will be gatting 2 Mbps but u may get it till tat limit and it may fluctuate between 256 kbps to 2 mbps
I personally get a d/load speed of 26KBps (kilo Bytes) wich is 26 x 8=208 Kbps (kilo bits) while using torrents on this MTNL plan
__________________________________________________ _______
Rep me if u like my posts
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 09-03-2008, 11:57 PM   #4 (permalink)
iMav's Avatar
cap means any data amt dwnld limitation
iMav is offline
Old 09-03-2008, 11:58 PM   #5 (permalink)
Hey thanx yar, i really had no ides abt it.
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 09-03-2008, 11:59 PM   #6 (permalink)
Stuge's Avatar
(2 mbps conx)
you can download 1250mb for day time (b/w 8:00am to 12:00) .and at night time you can download maximum what you can download b/w 12:00am to 8am
Stuge is offline
Old 10-03-2008, 12:06 AM   #7 (permalink)
iMav's Avatar
^^ whats the total cost ?
iMav is offline
Old 10-03-2008, 12:12 AM   #8 (permalink)
Stuge's Avatar
749+TAXES.
http://mtnldelhi.in/broadband/triband_tariff.htm
Stuge is offline
Old 10-03-2008, 09:36 PM   #9 (permalink)
If u are at mumbai, its Rs. 849 (DSL Night UL plan) and if u already hv a Triband connection and want an upgrade, then giv them a written letter abt a "Change in Triband Plan from ___ to ____" and this will be done within 8-10 Hrs flat
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 10-03-2008, 11:34 PM   #10 (permalink)
Also, in MTNL Uploaded data is not counted.........I mean Upload is free.
ico is offline
Old 10-03-2008, 11:48 PM   #11 (permalink)
iMav's Avatar
thank u for the info
iMav is offline
Old 11-03-2008, 05:30 PM   #12 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
Gone are the days of the 2 mbps connection ... I used to get around 2 mbps speeds but it's down to the usual 256 kbps on my TriB_Unlimited connection .. anyone still getting the same old super speeds ?
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 11-03-2008, 05:49 PM   #13 (permalink)
ex3n1us m4x1mus
preshit.net's Avatar
Hey iMav,
I've been using the 849NU plan from the day it was introduced. As he rightly said:
The speed depend on a lot of factors.
Uploads are indeed free.
You must disconnect / reboot the router at 00:10 and 7:50 ( Just to be safe )
The speed drops to arounf 500kbps for me just after midnight, probably because everyone starts download stuff. But by around 4AM or so, I easily touch 2Mbps.
Charges are 849 + Tax
Uzgimaga
preshit.net is offline
Old 11-03-2008, 06:50 PM   #14 (permalink)
iMav's Avatar
i was planning to go for 2 plans 1 for surfing and for downloading but 900 + 700 is costly if the total were 1300 i wouldv gone for it
iMav is offline
Old 11-03-2008, 06:52 PM   #15 (permalink)
ex3n1us m4x1mus
2 plans ? You have two landlines ?
Uzgimaga
Old 11-03-2008, 06:55 PM   #16 (permalink)
iMav's Avatar
no 1 is tata broadband 128kbps
iMav is offline
Which is ur best band darkknight Chit-Chat 26 07-06-2007 10:50 PM
help me on broad band..... s_arka_r QnA (read only) 4 02-05-2007 08:33 PM
New to Broad Band pls help!! dinesh_mettur QnA (read only) 7 07-01-2007 08:23 AM
MTNL Tri-Band leanpaws QnA (read only) 1 16-10-2005 09:08 PM
