Old 21-08-2004, 01:57 PM   #1 (permalink)
Default CMOS Error
Hi,
I am using PIII on intel 810.Recently, while booting the screen shows CMOS checksum error.I changed CMOS battery but to no avail.Kindly help.
drost77 is offline
Old 21-08-2004, 10:36 PM   #2 (permalink)
busyanuj's Avatar
get the motherboard checked by the technician soon.
busyanuj is offline
Old 25-08-2004, 03:31 PM   #3 (permalink)
Just check the jumper settings.If the jumper is in the clear jumper mode.If it is then change the settings. U can check it int he m/b manual.Bcoz the same prb was in their in one of my client M/C. I m sure it will solve the prb.
sammy is offline
