Old 10-12-2007, 12:35 AM   #1 (permalink)
mobilegeek's Avatar
Question How to Reduce the resolution of Bulk Photos.?
I want to reduce the resolution of my photos...
I know there is method of reducing the size of jpeg photos,
one is open MS Paint, Menu>Image>Strech&Skew... thats simple and easy .. but the point is I have to do it regularly, and like right now I have 300-400 photos in my Memory Card that i need to reduce the resolution to just store the photos in phone viewing and wil keep the ull Size photos for printing in computer Harddisk.. thereby keeping my card free.. So is there any way to reduce the size of large no of photos in smaller size.. or we can create some batch file or something. All the photos are in 3MP or 5MP right now. Doing one by one is not possible,
Plz advise.
Regards
mobilegeek is offline
Old 10-12-2007, 12:42 AM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: How to Reduce the resolution of Bulk Photos.?
simple
www.fotosizer.com
Fotosizer is a freeware batch image resizer tool. It resizes your photos in just 3 easy steps - 1. Photo selection, 2. select resize settings, then 3. Start the resize!
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 10-12-2007, 12:45 AM   #3 (permalink)
mobilegeek's Avatar
^ Thanx man ..
Old 10-12-2007, 01:03 AM   #4 (permalink)
prasad_den's Avatar
Why new softies, when irfanview can do all....??
Open Irfanview >>>> File >>>> Batch Coversion..
Here add all the files you need to convert/change resolution..
In the batch conversion settings, check advanced options box, and then click set advanced options..
Now play with all the settings you need, and click okay... Job done..!!
prasad_den is offline
Black & White Photos 2 Colour Photos Shasanka_Gogoi Software Q&A 5 10-07-2007 04:45 PM
Bulk scrapping in ORKUT. nithinks Internet & WWW 12 09-01-2007 09:41 PM
Download Fonts In Bulk readermaniax Internet & WWW 8 27-03-2006 10:53 AM
Bulk Forwards to another ID Dipen01 QnA (read only) 8 23-03-2006 10:46 PM
How to Convrt BMP..into JPEG...IN BULK Chindi_Chor QnA (read only) 17 28-02-2006 08:33 PM
