HELP HELP!!!!!!!! URGENT
Today I have put an EFY cd into my CD-RW to install a software I kept pressing the Shift Key to avoid the autorun suddenly there was a blast sound!!!!!!
I switched of the system immediately. I slowly tried to open the cd tray. The cd was broken into many many small pieces!!!!!!!!!!!!
What should I do?
Does this happen sometimes??
Is it due to the laser beam??
It is around 2 years old until now I didn't face even a single problem.
few small pieces are still inside!!. Should I give it for service? or cleaning up the drive ie.. removing the peices and try again? will it work?
Has anyone experienced such a prob before?
