08-12-2007, 07:07 PM
Just Do It
Weird Problem Browsing some Websites
When I hit www.google.com in the browser, it redirects me to http://64.28.180.146/index.php, then it open pages located in this site http://clckm.com/?dn=xxxx.com, only the xxxx.com changes to other names, the other link remains same when I enter google.com several times.
There is nothing wrong with my broswer nor computer as many other websites work without any hassles.
08-12-2007, 07:09 PM
Deadman Walking
Re: Weird Problem Browsing some Websites
is this the same issue with all of your browsers
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
08-12-2007, 07:24 PM
Dreaming Future
man its clear case of browser hijacking..... Try to remove it through Malware removing tools
World without Computer is like a man without Brain.....
08-12-2007, 07:59 PM
Just Do It
Ths happens on all browsers.
Like ?
08-12-2007, 08:19 PM
TechTin.com
you are infected from some adwares and spywares.
Try other browser like..firefox or opera..
I am sure..you can surf using those browsers.
But that is not final solution..you need to remove those unwanted malwares using antivirus and antispywares.
08-12-2007, 08:35 PM
TheSaint
What are your DNS numbers? Are you using those provided by your ISP or some other? Looks like a simple DNS lookup problem to me
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
08-12-2007, 09:29 PM
If it happens on all browsers like Opera and Firefox also, check your hosts file... See http://www.mvps.org/winhelp2002/hostsfaq.htm and check the hosts file for suspicious entries...
Arun
08-12-2007, 09:56 PM
TheSaint
@sakumar79---You know he's running Vista?
Oh and by the way, a HOSTS file in Windows, now doesn't that look familiar
/etc/hosts
Reason: Automerged Doublepost
08-12-2007, 10:55 PM
@NucleusKore, didnt get you... Whether he is running Vista or XP or 2k, HOSTS file is used... And if UAC is turned off in Vista, etc, it is possible for the file to get edited without knowledge...
I think HOSTS file has been available since Windows 95 and is possibly similar to what Linux does in /etc/hosts...
Arun
08-12-2007, 11:56 PM
TheSaint
Ok sorry I did not know, I edit the DNS directly in the TCP/IP settings in the LAN properties.
09-12-2007, 06:31 PM
Just Do It
AVG shows nothing infected.
How do I find that out ? BTW, I am using the Dataone BRoadband.
I am on Win 98 SE.
09-12-2007, 06:43 PM
TheSaint
I do not reacall how to do that in windows 98, but I think you have to open my computer-> Dial Up Networking, or is it in Network Neighbourhood? Anywya right click on your LAN and select properties, in that TCP/IP. You will see the primary and secondary DNS number in that
09-12-2007, 06:57 PM
This looks like a browser hijack to me buddy. Go to <windows dir>\system32\drivers\etc. There are two files there, Hosts (without extension) and lmhosts.sam. open these files in notepad and try to look at lines like
www.google.com http://64.28.180.146/index.php
These are redirections that may be causing the problem. Remove them all, just leave the localhost 127.0.0.1 redirection. Hope this solves some problem.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
10-12-2007, 01:37 PM
TheSaint
There is the problem in your lan properties. Both the DNS are WRONG, and might even be malicious. It might have been changed by some virus/malware. Delete both those numbers and add these
BSNL
61.1.96.69
61.1.96.71
MTNL
203.94.243.70
203.94.227.70
Airtel
125.22.47.125
Alternatively, use OpenDNS (any ISP)
208.67.222.222
208.67.220.220
10-12-2007, 01:56 PM
Just Do It
This is what the dataone engineer entered in the box.
Thanks NucleusKore, it worked. All websites function normally.
Great to have guys like you on this forum.
10-12-2007, 05:28 PM
TheSaint
You're welcome.
Now that you have cured the symptom, lets cure the disease. If you have 256 MB RAM or more
1. Register for a free email at aol.com
2. Throw away your existing antivirus
3. Go to http://safety.aol.com and download their free antivirus (its McAfee)
4. Install and scan your system
DNS numbers are not supposed to change by themselves
Search this Thread |
