Old 08-12-2007, 05:19 PM   #1 (permalink)
Default Increasing c drive size without formating
Hey can any 1 help me in incresing my c drive without needing to reformat it or loosing data on it.
Parminder001 is offline
Old 08-12-2007, 06:15 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Talking Re: Increasing c drive size without formating
If u use windows xp and it is installed in the C: drive then resizing the drive would kill ur installation as XP will not recognize the drive after resizing. Though u can skip that using some registry hacks.
But if u r not using XP or XP is not on C: drive then u can easily change the drive's space in disk management console. To open it simply go to Control Panel > Administrative Tools > Computer Management and then go to the Disk Management under the storage tab.
debsuvra is offline
Old 08-12-2007, 06:25 PM   #3 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: Increasing c drive size without formating
Turn-off System Restore on all drives this will gains you app. 2GB of space
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 08-12-2007, 06:33 PM   #4 (permalink)
prasad_den's Avatar
Can you explain..??
prasad_den is offline
Old 08-12-2007, 06:49 PM   #5 (permalink)
Deadman Walking
i also wants the same
Learn to live... &
Live to learn...
Old 08-12-2007, 07:06 PM   #6 (permalink)
TheSaint
NucleusKore's Avatar
I have done it using GParted. A student of mine had a laptop with a single partition (like all these crazy manufacturers supply). I resized 80 GB to 20 GB. When I rebooted it said new hard disk found.......blah blah, your device is installed and ready to use. I rebooted again for safety...you know windows
No problems after that.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 08-12-2007, 09:36 PM   #7 (permalink)
Best Solution go for Partition Magic 8.0 as you got Windows XP in your assembled PC
paid is offline
Old 08-12-2007, 09:41 PM   #8 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
I want to do it via my ubuntu. how can I? i need to merge C and D drive then convert them to ntfs. D is empty.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 09-12-2007, 09:30 AM   #9 (permalink)
tweety_bird_bunny's Avatar
ya, go with partition magic
tweety_bird_bunny is offline
Old 09-12-2007, 10:53 AM   #10 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
i think there are variuos softwares to do this ...
is there a way ... to dod it in vista... want to know .. but since i was using xp long back... i did it with partion magic or manager .. iforgot the name..
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 10-12-2007, 12:57 PM   #11 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
pm is a good softy ........ easy use .....
follow this thread bt its VISTA wala .......
Merging 2 partitions
... W H O T ...
ax3 is offline
Old 10-12-2007, 04:33 PM   #12 (permalink)
Use the Partition Magic which will gives us more disk functionality like creating, formating, merging, resizing
from mahesh kurade
Mahesh Kurade is offline
Old 10-12-2007, 05:59 PM   #13 (permalink)
TheSaint
But back up your data first, else it may look like Partition Tragic
Size problem aftr Formatting USB Drive Garbage Peripherals 7 19-06-2007 06:46 PM
Large Image files Size to Small Images Size. Charley QnA (read only) 14 03-03-2007 01:19 PM
What is maximum size of .pst file in microsoft outlook And Can I increase .pst's size fazle Software Q&A 1 25-02-2007 11:53 PM
Formating hard drive query.... Charley QnA (read only) 5 02-12-2005 09:33 PM
Reducing Size of USB Flash Drive... sms_solver Hardware Q&A 4 28-10-2005 02:22 PM
