Old 08-12-2007, 04:22 PM   #1 (permalink)
ajayritik's Avatar
Default How to convert a 9GB Movie into 4 GB?
How can I compress a 9 GB DVD movie to 4 GB movie? So that I can store it or burn it to a 4.7 GB DVD! I know about 4gb to 700 MB rip but how about 9 GB to 4 GB?
ajayritik is offline
Old 08-12-2007, 09:12 PM   #2 (permalink)
Default Re: How to convert a 9GB Movie into 4 GB?
I you want to make a movie DVD then there are several programs available for that. Use DVDShrink. Its a very easy tool. If you have Nero installed then it also contains a similar tool called Nero Recode.
If you want to convert it into AVI then you have also many softwares like Auto Gordan Knot.
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 08-12-2007, 11:25 PM   #3 (permalink)
raksrules's Avatar
I suggest you convert / shrink the DVD9 to DVD5 and copy the content on a standard 4.7 Gb DVD. I will tell what i used for this.
1. Shrink to 5
2.CloneDVD2
I used shrink to 5 to shrink and copy the contents on DVD9 on the HDD. Then used the CloneDVD2 to burn the standard DVD.
raksrules is offline
Old 09-12-2007, 12:40 AM   #4 (permalink)
ajayritik's Avatar
Are the above softwares free?
Old 09-12-2007, 03:57 AM   #5 (permalink)
dvd shrink
Faun is offline
Old 09-12-2007, 04:03 AM   #6 (permalink)
 Macboy
goobimama's Avatar
But I'd suggest you better just convert it into a 2-2.5GB x264 instead of using DVDshrink. Horrible blocking during high action scenes, it's almost unwatchable.
I'm like a bird... :)
goobimama is offline
Old 09-12-2007, 04:03 AM   #7 (permalink)
Evil Genius
faraaz's Avatar
^^ - +1 ... I used it a lot and it works great. Its probably a shareware version and if it is...there's ways around that yeah?
Roses are #FF0000, Violets are #0000FF...All of my base are belong to you!
faraaz is offline
Old 09-12-2007, 08:17 PM   #8 (permalink)
ajayritik's Avatar
goobi mama give me more details how to burn a movie of 9 GB into 2 separate DVD's of 4 GB each?
Old 09-12-2007, 08:54 PM   #9 (permalink)
 Macboy
goobimama's Avatar
Well I'm no expert at encoding, I hardly encode any of my stuff so I can't help you there. But you could google around for info on how to encode to x264 codec. It's somewhat like Xvid, only it has better output at lower file sizes... so if you keep it at a high 2GB per DVD9 movie, there should be no noticeable loss in quality. You could even make it 700MB with a 5.1 soundtrack and it still looks good...
Old 09-12-2007, 08:58 PM   #10 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^it takes ages to encode in xvid.This sux!
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 10-12-2007, 10:19 AM   #11 (permalink)
Swalpa Adjust Maadi
RaghuKL's Avatar
Clone DVD is very good and very fast
if you have noticed this notice you will have noticed that this notice is not worth noticing
TRUTH IS OUT THERE
Do right and fear no man.
In word without walls, is windows (7) really needed?
RaghuKL is offline
Old 10-12-2007, 10:50 AM   #12 (permalink)
ajayritik's Avatar
Is it possible to break a 9 GB movie into two equal halves and then burn the first half on a 4.7 GB DVD and the other part in another 4.7 GB DVD? I guess there will be problem with the sequence. I feel if we compress the movie from 9 GB to 4 GB there maybe some loss of quality especially with the picture quality.
Old 10-12-2007, 10:58 AM   #13 (permalink)
raksrules's Avatar
@ajayritik
The best way is the compress the DVD9 to DVD5 and burn. The above mentioned softwares by me are not freewares. Shrink to 5 is shareware and clonedvd2 comes with 30 days free trial. I have used this within the trial period and have burned 5 to 7 original DVD9 discs to DVD5 using this tool. Total time taken for 1 DVD to complete the whole process was approx 45 min. Loss of quality is there but you wont notice much.
Old 10-12-2007, 11:57 AM   #14 (permalink)
ajayritik's Avatar
But is the loss of quality too apparent? Is it more loss of picture quality or sound quality?
Old 10-12-2007, 12:05 PM   #15 (permalink)
raksrules's Avatar
Sound will stay as it is 5.1 etc or whatever it has. The picture will definitely loose its quality but the difference wont be that evident. This is what i feel. If you are a videophile and cannot tolerate the loss then the best option is to convert the DVD to a 2 CD Xvid. But the effort required to too much for doing so and hence it is not recommended.
Old 10-12-2007, 12:32 PM   #16 (permalink)
ajayritik's Avatar
rakoo7 as I told you earlier I'm OK with burning an 8 GB DVD into two 4GB ones. You have suggested "convert the DVD to a 2 CD Xvid". I don't want to convert to CD.
Old 10-12-2007, 02:04 PM   #17 (permalink)
raksrules's Avatar
With 2CD rip i meant that the DVD9 gets ripped in two AVI files totalling to 1.36 Gb (approx). As far as your requirement goes of burning the DVD9 on two DVD5s then i am sorry i dont have much idea on how can you split the same.
On workaround is that you can use DVD Decrypter and copy the main movie from the DVD9 on to your HDD then split the DVD files and individually burn them on DVDs in DVD format only. But this technique is not tried and i would recommend you dont try it.
May be if you have the requistite time to invest then i suggest (only if your DVD player is capable of playing DivX/XviD) you rip the DVD in a custom size (say 3.5 to 4 Gb) and also the sound as 5.1 AC3 DOLBY DIGITAL then you will get excellent quality rip. After you get the output video you can burn the same on a DVD and play it in your player (but like a normal avi/Divx file)
Old 10-12-2007, 05:15 PM   #18 (permalink)
CpyderGraphix
cpyder's Avatar
you can use DVD Shrink for splitting DVD9 into two DVD5 discs. Although its a kinda workaround.
launch DVD Shrink -> Reauthor -> DVD Browser
Drag initial tracks onto left pane - usually one track would be .99 GB, so you can place upto four tracks. You can adjust compression settings ofcourse.
Click 'Backup' to make an image/burn it.
Repeat the process for the remaining tracks and burn onto second disk.
Caution: You will lose Menus with this method, but the movie quality will not be compromised if you dont compress it (obviously ). The disks will be compatible with standard DVD players as well.
And I love DVD Shrink because of two reasons :
-Its free.
-Its so small!! Its not even 1 MB and does wonders.
See you at anditworkedforme.com
cpyder is offline
Old 26-04-2008, 03:35 PM   #19 (permalink)
Although DVD Shrink is a superb tool but it fails when a DVD size is more than 7.5 GB, as the result DVD5 will be more than 4.38 GB and normally available DVDs are of 4.38 GB(written 4.7GB).I too search for a tool by which I will have control over the size. I tried the DVD rebuilder but on a core-2-duo 2.2GHz machineit took around 5hours to complete the job. Has anybody any idea about something better
suniltr77 is offline
Help needed to convert avi/divx/xvid movie to DVD!! anuj763 QnA (read only) 9 20-12-2007 05:20 PM
can i convert DVD movie into VCD format harshagarwal QnA (read only) 3 27-09-2005 11:20 PM
Convert a DVD movie to a 700 MB CD anilthomas26 QnA (read only) 5 01-09-2005 02:54 PM
can we convert divx movie to norma vcd (mpeg) ...... fanatic QnA (read only) 4 28-08-2005 01:07 PM
HOW TO CONVERT DVD MOVIE INTO ANY OTHER FORMAT nirajan QnA (read only) 10 14-09-2004 06:48 AM
