Friends,
I had a folder in on my hard-disk which was protected by my Windows XP as a Personal Folder. After formatting my C: drive, this folder has become inaccessible because the userId's do not match. The files still exist on D: drive. I am aware of certain RAW Data extractors which directly read data from the HDD. Can you please tell me some of them, so that I can extract my file?
Thank You....
But I guess your problem may be a little more complicated. When you protect a folder, the way you've done, XP encrypts that folder. So, even if you can recover the file, it is more likely to be encrypted!!
All the best.
See you at anditworkedforme.com
