07-12-2007, 12:37 PM
How to rip a DVD into AVI?
Can someone suggest softwares to rip a DVD into smallersize? I know there is one link in which chotacheeta has given instructions to rip a DVD using Auto Guardian but that takes a very long time. Can someone suggest some other softwares that rip/compress a 4.5 GB or 9 GB file to a smaller size preferably around 700 MB?
07-12-2007, 12:52 PM
Rebooting
Re: How to rip a DVD into AVI?
asked many times brother !!! please use the search feature at Digit or in Google
there are many tutorials available on a software (free) which considered to be the best in business, AutoGK
you may try this one also..
http://www.chotocheeta.com/2007/08/2...-2-cd-dvd-rip/
rebooting
ChotoCheeta.com
07-12-2007, 12:55 PM
Deadman Walking
ajay chaala mandi adigaaru same question, auto gordian knot try chei quality baagundi
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
07-12-2007, 12:56 PM
Rebooting
rebooting
ChotoCheeta.com
07-12-2007, 12:58 PM
Deadman Walking
choto cheeta this is telugu language where ajay and i always communicate with each other we both are from andhra pradesh
Learn to live... &
Live to learn...
07-12-2007, 12:59 PM
Rebooting
ohh... and I thought you said some thing (may be some dirty  ) to me
rebooting
ChotoCheeta.com
07-12-2007, 01:02 PM
Deadman Walking
cheeta you are my senior member i don't know your age but you are senior to me in this tech field , i will always respect you,pathiks e.t.c;
Learn to live... &
Live to learn...
07-12-2007, 02:00 PM
I suggest do not go for ripping the DVD to avi since it is a time consuming process. Better just make a copy of the DVD and keep it. In case it is a DVD9 then used DVD Decrypter/ DVD Shrink to make it fit into 1 standard DVD. But ripping is a bad idea. Thats what i feel.
07-12-2007, 02:05 PM
Well this is not for me but for my friend! Since I dont have a large enough flash drive to give the movie to him the only option that's left with me is to rip into a smaller size.
batista, I know that the quality is good with Auto Guardian Knot but it's a very time consuming process, so I was looking for some other options!
07-12-2007, 02:21 PM
99.9% Idle
Ripping takes some time and you need to go with it no other way..the reason it takes sometime is bcoz of two pass encoding...if you use converters, takes less time but quality will suffer.
07-12-2007, 02:27 PM
Deadman Walking
ajay what axxo said is 100% right, ripping means a time consuming process, how can a good quality comes without waste of time
Learn to live... &
Live to learn...
07-12-2007, 02:52 PM
Hey can someone give me info about how the titles below our names are decided? Any rule for that? For example my title is IN THE ZONE!
07-12-2007, 02:56 PM
Deadman Walking
ajay go yo your User CP->edit profile which you will find above , there under custom user title enter your desired title
Learn to live... &
Live to learn...
07-12-2007, 03:08 PM
NP : Crysis
try choto's tut...its really gud..and yeah use AutoGK. its gud
07-12-2007, 03:20 PM
Search this Thread |
