Old 27-03-2005, 12:53 AM   #1 (permalink)
Chillum Baba
a_medico's Avatar
Default [RAM] 512 MB or 256+256 ?
my 256 RAM has broken down. wanna upgrade to 512. shall i go for a single 512? or two 256 will be better? or doesnt make any diff?
most of the vendors suggest hynix? will that be ok?
approx price?
thanks
a_medico
ps - what is difference betwn sd and ddr rams?
a_medico is online now
Old 27-03-2005, 01:02 AM   #2 (permalink)
swatkat's Avatar
http://www.thinkdigit.com/forum/viewtopic.php?t=17198
http://en.wikipedia.org/wiki/DDR200
http://swatrant.blogspot.com/
swatkat is offline
Old 27-03-2005, 09:11 AM   #3 (permalink)
enoonmai's Avatar
Just one quick note. Make sure your motherboard supports a single 512MB RAM module. Refer the other thread for information on whether you need 1x512 or 2x256. My advice, if you're not planning to do a heavy duty upgrade, go for the 2x256. If you're planning on uprading soon enough, go for a 1x512. You dont want to take up more RAM slots in case you wanna upgrade. Hynix will offer good enough performance at its cost. If you want a higher performance RAM and are willing to spend more, then go for a Transcend.
Playing FEAR XP/LSW2
enoonmai is offline
Old 27-03-2005, 09:45 AM   #4 (permalink)
Chillum Baba
a_medico's Avatar
thanks enoonmai, i will go according to ur suggestions..thanks again
Old 29-03-2005, 08:04 PM   #5 (permalink)
I maybe some late on this, but just wondering if your motherboard/processor supported dual-channel memory. If it did, you might think of 256x2 rather than 512x1.
DH
Where is the wisdom we have lost in knowledge?
Where is the knowledge we have lost in information? - (Choruses from the rock - T.S. Eliot)
Doc Holliday is offline
Old 29-03-2005, 09:30 PM   #6 (permalink)
just go for 2*256
जय माता दी
It\'s Ok.... u r the best ,,,, i can speak more lie ,if u r happy with it,,, WWW.GOOGLE.COM is BIG BOSS !!!
imprince is offline
Old 30-03-2005, 10:21 PM   #7 (permalink)
Go for 1 stick , from this upgrade option will be open and a single stick cost less than the combined price of 2 sticks.
IN HOUSE GEEK!!!!!!!!!!!!!!!!!!!!
chirayu garg is offline
