Old 05-12-2007, 07:01 PM   #1 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Merging 2 partitions
I just removed Linux from my computer, now I have 3 partitions with all having NTFS file system
1) Vista 15 GB
2) 8 GB empty partition
3) Rest files partition
I wanna merge the vista & 8 GB partition for a total of 23 GB partition, but the problem is Vista's partition is the boot parition & I don't wanna loose my OS.
How to do this safely?
about.me/gxsaurav
gxsaurav is offline
Old 05-12-2007, 07:14 PM   #2 (permalink)
j1n M@tt's Avatar
Default Re: Merging 2 partitions
hey man,u can merge dat 2 partitions(including boot) simply using Magic Partition....
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 05-12-2007, 09:57 PM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
I thought you already merged your partitions!
http://www.thinkdigit.com/forum/show...&postcount=146
kalpik is offline
Old 06-12-2007, 05:17 AM   #4 (permalink)
Krazy_About_Technology's Avatar
well i tried it once but vista's inbuilt partition manager doesn't allows to change the boot partition size. System partition can be changed if its different from boot partition. You can use gparted live cd or the SUSE live cd to merge your partition. But even these sometimes have trouble resizing the first primary partition. Try it, its safe, it first runs a simulation and only does real resizing if everything is alright. But in anycase, keep the Ultimate boot cd handy to repair partition table in case of any problems.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 06-12-2007, 06:20 AM   #5 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
and I want to give saurav company
I have an ubuntu install.
My first two partitions are FAT23 with Win XP and NTFS with some user files respectively
I want to merge them without loosing data, and convert all to NTFS
Help Milega?(I want to try it from Ubuntu Feisty)
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 06-12-2007, 08:30 AM   #6 (permalink)
kalpik's Avatar
Please suggest his something that runs from windows.. We wouldn't want him to get more frustrated by using more of Linux
kalpik is offline
Old 06-12-2007, 09:11 AM   #7 (permalink)
TheSaint
NucleusKore's Avatar
Yes ^+1
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 06-12-2007, 09:51 AM   #8 (permalink)
partition magic is your friend
you can also try gparted if you don't have money
P.S. Backup is a must and do at your risk!!!
littledrop is offline
Old 06-12-2007, 11:22 AM   #9 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
I recommend a reinstall it always work for me.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 06-12-2007, 01:05 PM   #10 (permalink)
Well, i just suggested what i used. I see technology as an enabler, something that i use for my own gains. So it doesn't matter to me who made what? as long as it works for me, i m on it. I've got a kind of Lin+Win = Win Win (dont confuse the context ) situation.
Old 06-12-2007, 01:50 PM   #11 (permalink)
gooby pls
Third Eye's Avatar
@Gxsaurav: First convert the 8 gb partition to NTFS and merge it with 15GB vista partition
by using Partition Magic 8(I think it doesn't work in Vista Use it in XP )
Third Eye is offline
Old 06-12-2007, 03:05 PM   #12 (permalink)
kalpik's Avatar
I know! But we are talking about GX here
kalpik is offline
Old 06-12-2007, 03:16 PM   #13 (permalink)
din
Tribal Boy
din's Avatar
@Krazy_About_Technology
Seems you missed this thread
That is what Kalpik and others meant lol.
@gx_saurav
I think partition manager will do it ? If you have no plan to buy, you can 'borrow' from someone for single use
din is offline
Old 06-12-2007, 03:25 PM   #14 (permalink)
gxsaurav's Avatar
I already have partition magic 8.5 for Windows, so application is not a problem anymore.
When I selected to merge partitions in Partition magic, I selected the 8 GB partition which is a NTFS Partition the first one, with 15 GB vista partition which is the only OS & boot partition. PM 8.5 said it will copy files to some folder & then merger...but since it is a boot partition i m afraid of data loss.
Now here is the thing, I already have a Norton ghost disk image with me as the last resort, if my Vista refuses to boot I will simply delete both the 25 & 8 GB partition using PM 8.5 recovery CD, then make a big 23 GB partition in the available space & revert the ghost image...but this is the last resort.
I m going to take a risk, merging both partitions in PM 8.5 now....c ya in a while if my system is still in working condition.
about.me/gxsaurav
gxsaurav is offline
Old 06-12-2007, 03:26 PM   #15 (permalink)
din
Tribal Boy
din's Avatar
@gx_saurav
I am not sure about Vista, but I have tried merging boot partition (XP) with another. Worked without any problem.It should not be a problem for Vista too, but again, not 100% sure.
din is offline
Old 06-12-2007, 06:28 PM   #16 (permalink)
gxsaurav's Avatar
I backed up everything I could on my C: drive & have started the process in Paragon partition manager 8.5....
wish me luck, pray for me...c ya in few hrs
about.me/gxsaurav
gxsaurav is offline
Old 06-12-2007, 06:46 PM   #17 (permalink)
Google Bot
Pathik's Avatar
^^ yup it ll work flawlessly.. just merge the other partition with the vista one..
Pathik is offline
Old 06-12-2007, 07:59 PM   #18 (permalink)
gxsaurav's Avatar
This is how it shows here... I selected first my vista parition & then on 2nd page my empty partition....
Gr8..i tried it, chewed half my fingers but nothing happened...
This is first page of partition manager 8.5, I selected my Vista partition here,
This is the 2nd page where I selected my 8 GB partition. On 3rd page it showed as I wanted but said the files are in use so it needs to do a reboot. I did that,,,& on boot this is the screen I got (Taken from phone)
It did the operation but nothing happened, I still had 2 partitions.
Now, when I try selecting my 8 GB partition in first page & then vista partition, it says "it's a boot partition which u r merging to non boot. You won't be able to boot"
how to do it now
about.me/gxsaurav
gxsaurav is offline
Old 06-12-2007, 08:03 PM   #19 (permalink)
Google Bot
Pathik's Avatar
Try one thing, Merge both the partitions and Ignore the Boot errors.. Then pop in the Vista dvd and repair vista and rewrite the MBR with Vista's boot loader.
Pathik is offline
Old 06-12-2007, 08:58 PM   #20 (permalink)
gxsaurav's Avatar
Hmm...I hope there won't be data loss in this case...ok trying that.
I tried the above method...but nothing happened. It wiped my boot loader & I had to restore it using Vista DVD but still I was left with 2 partitions...
now going the long way. I m making a Disk image using backup & restore center of Vista on my external HD then format both Vista & 8 GB Partition, merge them,...reinstall vista then restore the disk image.
C ya all tomorrow
about.me/gxsaurav
gxsaurav is offline
Old 09-12-2007, 11:37 AM   #21 (permalink)
gxsaurav's Avatar
I did it the long way...
I started Windows backup & restore center & made a complete replica image of my C drive which came out to be 10 GB on my external HD.
Then booted from Vista DVD, deleted & merged both the 15 GB & 8 GB partition to make a big 23 GB Partition.
Then using the Vista DVD, I reapplied the old backed up image & repaired the bootloader....
Vista to the rescue
about.me/gxsaurav
gxsaurav is offline
Old 10-12-2007, 12:44 PM   #22 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
so long way does work ......
pm didnt do it ..... right ........
... W H O T ...
ax3 is offline
Old 10-12-2007, 03:57 PM   #23 (permalink)
Very nice. Vista's Rescue mode is quiet useful, i myself repaired my system 2 times with it when i accidentally deleted linux partitions in the wrong way and was stuck with grub boot loader error. Have fun buddy
Old 11-12-2007, 08:50 PM   #24 (permalink)
Use Partition Magic 8.05 & note that both the partitions should be in same format , i.e. in NTFS or FAT. The u'll be able to merge both partitions without any data loss.
ninad_xpress is offline
Merging partions in Vista Ishan Software Q&A 5 10-02-2008 08:49 PM
>26 HDD partitions...? Projjwal Hardware Q&A 15 27-06-2007 11:36 PM
Merging SP2 with XP cd ComputerUser Software Q&A 8 14-05-2007 04:51 PM
Merging Partitions - HELP !!!! dreams QnA (read only) 8 29-01-2006 12:34 PM
abt partitions and 7610 ranjodh QnA (read only) 3 03-04-2005 01:32 PM
