Old 05-12-2007, 11:39 AM   #1 (permalink)
ajayritik's Avatar
Default How to split a VOB file into smaller size?
Can someone suggest a software to split a VOB file into smaller parts? I got one such software from the net but that is not so intuitive. I need a software like VCD Cutter in which we can preview the file and then cut or split it at a particular scene rather than splitting it without knowing where! Can anybody suggest some softwares? Preferably free!
ajayritik is offline
Old 05-12-2007, 11:52 AM   #2 (permalink)
Rockstar11's Avatar
Default Re: How to split a VOB file into smaller size?
Chopper XP 2.7 ( Freeware )
Sasta Sunder Aur Tikau DVD cutting program
Chopper XP is a DVD cutting program, that lets you extract part of a VOB file and save it as a new file.
Chopper XP is a Vob cutting program with a video display and a great interface. You just need to scroll to a location and select mark in and out points. The program also lets you set any priority of extraction and displays the estimated time left for extraction.
link : http://www.softpedia.com/get/CD-DVD-...opper-XP.shtml
Rockstar11 is online now
Split Video file? max_demon Software Q&A 6 16-11-2007 12:44 AM
How can I split/join a VOB file? ajayritik QnA (read only) 4 03-10-2007 06:39 PM
What is maximum size of .pst file in microsoft outlook And Can I increase .pst's size fazle Software Q&A 1 25-02-2007 11:53 PM
how to split Norton Ghost image file to save on CD digiFriend Software Q&A 2 05-03-2006 01:05 PM
Change File size in MB instead of GB in properties of a File rachitar QnA (read only) 4 24-11-2005 09:46 AM
