Old 04-12-2007, 05:28 PM   #1 (permalink)
ajayritik's Avatar
Default What is the difference between DVD+R and DVD-R?
I tried to search lot of information about the difference between the both and I found out that DVD-R was developed by Pioneer and DVD+R was develpoed by Sony! And also when I buy a blank DVD from the shop I mostly get DVD-R and I also heard that DVD+R are more expensive and some of the DVD players may not support it ! Anything apart from this! Are DVD+R available in India?
ajayritik is offline
Old 04-12-2007, 05:35 PM   #2 (permalink)
New
New's Avatar
Default Re: What is the difference between DVD+R and DVD-R?
DVD-R:
Benefits: Better DVD playback compatiblity within home DVD players.
Drawbacks: Older technology and less money behind the format means that they come out with faster media and burner technology slower. You will frequently see DVD burners that will support (for instance) 16X DVD+R and only 8X DVD-R.
DVD+R:
Benefits: Faster speeds, more inovations like Double Layer discs (8.5 GB)
Drawbacks: Will not play is some home DVD players. If you know your home DVD player will play DVD+Rs then there is no reason to not use them.
New is offline
Old 04-12-2007, 05:49 PM   #3 (permalink)
ajayritik's Avatar
New I found the same information when I googled. What I'm looking for is what are the benefits from a layman or a non technical person point of view!
Old 04-12-2007, 05:56 PM   #4 (permalink)
New
New's Avatar
Wait for some more reply
New is offline
Old 04-12-2007, 06:06 PM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
i think the benefits and drawbacks tell u the difference in layman terms
speed; dvd player support; newer technology anything more than that is a technical
http://beingmanan.com
iMav is offline
Difference Between DVI & D-Sub tiblu Hardware Q&A 2 31-05-2006 01:46 AM
NFS MW difference dgk.3007 Gamerz 15 18-05-2006 09:41 PM
What is the difference between C and C++? imagineer_aman QnA (read only) 21 05-07-2005 08:03 PM
difference sourav QnA (read only) 1 04-05-2005 06:02 PM
What is the difference between LCD and TFT debaisaindian TVs / Monitors 7 02-05-2005 12:48 AM
