Old 21-08-2004, 11:57 AM   #1 (permalink)
atul
Posts: n/a
Default Cd rom ! ! !
i use w2k .... & have cdr as well as cdrom ...
bt my bios doesn`t detect my cdrom ..... how can i manually + it ???
Old 21-08-2004, 12:01 PM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
What mobo r u using ? I hv Intel 810e based mobo and it can only detect 1 optical storage device. I tried to install both the writer and th cd-rom,but th cd-rom could not be detected.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 21-08-2004, 11:13 PM   #3 (permalink)
busyanuj's Avatar
hey claw, that's strange !
I use a 810 motherboard, and used to have both CD-RW drive and CR-ROM drive plugged into it before my CD-ROM drive went bust some months back.
both the drives used to work fine together.
busyanuj is offline
Old 22-08-2004, 01:20 PM   #4 (permalink)
Ethan_Hunt's Avatar
try Right Clickling on My Computer And then Click on properties go to Device Manager And then try to Expand the Cd-Rom Drive Icon and see if it is detected.
Ethan_Hunt is offline
Old 26-08-2004, 12:49 PM   #5 (permalink)
Jai Suresh
lywyre's Avatar
check the jumper settings in you CD Drive.
Also check that you have enabled Automatic detection of IDE drives in BIOS.
lywyre is offline
- by Charley
