Old 03-12-2007, 02:15 PM   #1 (permalink)
Default Help needed to convert avi/divx/xvid movie to DVD!!
can anybody tel me how to convert avi/divx/xvid movie 2 dvd withouty any loss of quality?
one more thing,..which software can i use to rip a scene from a dvd?
thanx in advance!!!
anuj763 is offline
Old 03-12-2007, 06:27 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
Default Re: Help needed to convert avi/divx/xvid movie to DVD!!
use gordian knot...the best open source ripping application there is,the interface is a little unintuitive though.
dIgItaL_BrAt is offline
Old 03-12-2007, 06:33 PM   #3 (permalink)
Deadman Walking
Batistabomb's Avatar
thanx in advance!!!
to rip your desired scene first cut the scene from chopper XP then use gordian knot
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 03-12-2007, 06:38 PM   #4 (permalink)
TheSaint
NucleusKore's Avatar
LOL....I think he is asking how to convert avi to a dvd and not the reverse!!!!!!! Read before you answer guys!!!!!!
There are two you can use:
Nero 6 Reloaded (Shareware) - which I have and use
AVI2DVD - which is freeware which I have used too.
To rip a scene use VirtualDub MPEG2, its a freeware too
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 03-12-2007, 06:43 PM   #5 (permalink)
Deadman Walking
You are right i am talking about reverse , fine but the above mentioned softwares by you suffers from quality degradation isn't it
Learn to live... &
Live to learn...
Old 03-12-2007, 06:47 PM   #6 (permalink)
TheSaint
In both Nero 6 Reloaded and Avi2Dvd there are two settings. The default is fast encoding. It takes one and a half hours on my system (AMD AM2) to make a full DVD. If I go for the high quality encoding, it shows and ETA of four hours. That setting is good.
Old 03-12-2007, 06:49 PM   #7 (permalink)
Deadman Walking
recieved a same quality as what a original DVD gives by 4 hours method, and what's the quality with 2 hours procedure
Learn to live... &
Live to learn...
Old 03-12-2007, 07:04 PM   #8 (permalink)
TheSaint
Look 4 hours gives better quality then 2 hours. Period. How close you get to OriginaL DVD depends on the quality of the Xvid itself. If you're asking me what should be the specs of an XviD or a DivX to be converted to ORIGINAL DVD quality I do not know
Old 03-12-2007, 07:22 PM   #9 (permalink)
Deadman Walking
ok well said i think size of movie will be greater in 4 hours one
Learn to live... &
Live to learn...
Old 20-12-2007, 05:20 PM   #10 (permalink)
oops...my bad!!!
Softwares used to convert VCD to Divx/Xvid Dipen01 Reviews 14 08-02-2009 03:26 PM
How to burn divx/xvid files to dvd to play in Divx player? casual_gamer Software Q&A 8 01-08-2007 09:49 AM
best program to convert dvd to divx/xvid royal Software Q&A 8 04-10-2006 12:44 PM
can we convert divx movie to norma vcd (mpeg) ...... fanatic QnA (read only) 4 28-08-2005 01:07 PM
