Old 21-08-2004, 11:50 AM   #1 (permalink)
atul
Posts: n/a
Default defrag ????
i have w2k .... & 20 gb hdd ....
Defrag-ing takes a very long time .... how 2 speed it up ????
& prevent it from stopping in between the process ?????
so that i can switch off my monitor & wait till it is over ....
nahi to everytime i switch it on, it is either paused or aborted ......
Old 21-08-2004, 12:15 PM   #2 (permalink)
sorry bro..but i don't think there is any way of speeding things up on
win 2k defragmentor. I suggest u use a third party utility like defragmentor premium etc. 2 really speed things up and it offers better features than the standard windows defragmentor.
prankzter is offline
Old 21-08-2004, 02:42 PM   #3 (permalink)
NikhilVerma's Avatar
Another soln is that defrag the sys in safe mode coz it uses least resources.....
NikhilVerma is offline
Old 21-08-2004, 03:06 PM   #4 (permalink)
If you use windows 98SE, you could speed up defragging by dloadin the unofficial Service Pack. It bundles the defragmentor that came with ME, and it really speeds things up.
For your system, the above two solutions will work.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 21-08-2004, 11:49 PM   #5 (permalink)
gxsaurav
Posts: n/a
Get Diskeeper 8
Old 22-08-2004, 12:14 AM   #6 (permalink)
Try Running Defrag in Safe Mode.
As you enter this life,I pray you depart
With a wrinkled face,And a brand new heart.
-- U2\'s Love and Peace or Else (HTDAAB)
svenkat83 is offline
Old 22-08-2004, 12:20 AM   #7 (permalink)
cool...I think that idea is really good. Try defragging in Safe Mode....
I too will try it
sUlPhUr|nE` is offline
Old 22-08-2004, 12:33 AM   #8 (permalink)
yeah that shul speed up the thngs a little
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 23-08-2004, 03:40 PM   #9 (permalink)
atul
Posts: n/a
& how often should we defrag the drive ???
bole to ... period ???? 2 3 months ke baadh ... ya ????
Old 24-08-2004, 11:24 AM   #10 (permalink)
atul
Posts: n/a
Old 24-08-2004, 04:42 PM   #11 (permalink)
bipin_hbk
Posts: n/a
There are analysing tool withdefragmentor to test wether you need a Defrag at the moment or nto. rather it is usualyy once in a 2-3 months
Old 25-08-2004, 11:39 AM   #12 (permalink)
atul
Posts: n/a
& how 2 prevent it from stopping in between the process ?????
Old 25-08-2004, 11:53 AM   #13 (permalink)
atul
Posts: n/a
i use w2k ...
Old 26-08-2004, 11:26 AM   #14 (permalink)
atul
Posts: n/a
& how 2 prevent it from stopping inbetween the process ?????
i use w2k ...
starting in safe mode is good ... bt any services 2 stop ????
Old 26-08-2004, 05:57 PM   #15 (permalink)
Jai Suresh
lywyre's Avatar
end all the unwanted process in the background using task manager
disable screensaver and power options
ensure that no other unwanted processes are running and then run defrag
lywyre is offline
Old 30-08-2004, 10:51 PM   #16 (permalink)
abhishekkulkarni's Avatar
Hey I converted my drive to NTFS.The defrag takes just 1 min.
May the source be with you ..
abhishekkulkarni is offline
Old 05-09-2004, 01:09 AM   #17 (permalink)
manishjha18's Avatar
try raxo perfect disk---its the best
http://drmanishjha.wordpress.com/
manishjha18 is offline
Old 15-09-2004, 03:32 AM   #18 (permalink)
Default defrag ????
Dowload DiskeeperLite.. it is a freeware and performs defragging much faster than windows.
When defragging, do the following to speed up defragging; otherwise you will get frequent messages of drive contents changing;
1. Disconnect from the internet if you are on a cable connection.
2. Disable Norton or any other anti-virus you may have installed.
3. Run Diskeeper Lite.
If you want a still faster defrag, run it in Safe Mode ( F8), then disable the antivirus.
vaidy9 is offline
Old 15-09-2004, 04:12 PM   #19 (permalink)
Default efficient defrag
When you install your system these are some tips to keep in mind so as to reduce the level of fragmentation.
1). Make partitions of large drives. It takes considerably more time to defrag a single large drive full of data as compared to smaller partitions.
2). Make different partitions for different purposes. Make one partition for Windows, another for games, another for program files, another for data.. etc as required. This way you only have to defrag the partition that you have added, deleted, installed files to.
3). A lot of the programs and games create temporary directories and saved games directory in your system drive, change those to the drive where you have installed your programs/games. If you do this you won't have to defrag your system drive as often.
4). Use a program like Diskeeper or O&O defrag.
5). If you use O&O Defrag, defrag your drives once you are done installing your system and programs. The next time you defrag, O&O will ony defrag the fragmented files.
I am.... Therefore I Think....
luckyrocker is offline
- by Charley
