i have put a signal of my radio to the line in jack.
now i want a software which can record the sound from the line in jack .
it should record direct to disk . it should also normalize the recording and also split into multiple files .
i know audacity also does it but if i record continuosly 2 hrs then it takes too much time in saving .
so i want a software which can also record direct to disk and in multiple files. but the most important thing is that it should simultaneously normalize the sound.
for example i start recording and it directly records to a mp3 file of length 10 minutes each continuosly with normalize feature.
it should be automatic
