@naveen_reloaded
actually any image with higer resoltuion can be used for poster printout... now if u need really big say 12ftx12ft, then u need to look for pro range resoluion like 4000x3000 or such...
usually Transperency films, when scanned will produce such or higher resolution... CAM model such as Nikon D80 or avobe will give such higher resolution when clicked at RAW mode...
when I scan a Transperency, a single file (usually the scans are stored in tif/tiff) format, sizes around 150 MB+ for one images
same case with digital too, RAW format of D80 may produce images at size of 75MB or more
So I am doubtful that u cant find downloadable options, and even if you find for example from sites like IndiaPictures.com, the service will be paid one !!!
thnx...
