I recently bought 2 Netgear PCI type wireless adapters. Model WG311GE. The connectivity is lost, like after every 2 or 3 hrs. The speed shows 1 MBps and signal strength is -low.My wireless router is Linksys WRT 54G. When I reset the security to - NO- and then again change it back to WPA-PSK(TKIP), it works again ! The signal strength will come back to Excellent and speed shows as 54 MBps.
I set the WPA-PSK(TKIP) in wireless adapter software the same as my router password. Does it has something like duration ? Like after 2 hrs it will expire or so ? But can't see any such settings in the software interface though.
This is some problem with the hardware /software ? Or just something I am doing wrong ?
