Old 30-11-2007, 12:46 AM   #1 (permalink)
bajaj151's Avatar
Default Problwm : Lite-On Disk Reading
There is problem is opening the contents of the disc....getting message as :
Prepare a Blank disc
29-11-07 (Current date)
Formatting Options
How can I solve this ?
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline
Old 03-12-2007, 12:40 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: Problwm : Lite-On Disk Reading
try checking cd\dvd @ ur frds place ..... if it works there, then clean ur drives lens ...... & then popin cd\dvd again ......
same happened with my sony drive & tried above thing & now almost all dvd`s r readable .........
... W H O T ...
ax3 is offline
Old 03-12-2007, 01:06 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
+1
ravi_9793 is offline
Old 03-12-2007, 03:37 PM   #4 (permalink)
bajaj151's Avatar
As..my drive is in warranty....so..can't open it...
Can I use..lens cleaner cd.......if yes...which one ?
bajaj151 is offline
Old 03-12-2007, 04:07 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
yes use lens cleaner CD.
There are plenty of such CD available in market.Just find any from your local market.
Old 03-12-2007, 04:33 PM   #6 (permalink)
ax3
ax3's Avatar
i never said 2 open it ........ just popin lens cleaner dvd ........
... W H O T ...
ax3 is offline
Old 24-12-2007, 03:58 PM   #7 (permalink)
bajaj151's Avatar
Lens Cleaner Cd worked for me.Thanks.
bajaj151 is offline
Old 24-12-2007, 04:50 PM   #8 (permalink)
Call me Sumit
esumitkumar's Avatar
^^ bump ..even my lite on isnt recognising CD lens cleaner also
esumitkumar is offline
Old 24-12-2007, 07:29 PM   #9 (permalink)
bajaj151's Avatar
Update your firmware.....
bajaj151 is offline
Old 25-12-2007, 09:36 AM   #10 (permalink)
Call me Sumit
^^ how yaar ?
Old 25-12-2007, 01:46 PM   #11 (permalink)
bajaj151's Avatar
^^ how yaar ?
Download firmware from
http://us.liteonit.com/us/index.php?...per&Itemid=153
Specify your model number and then download firmware accordingly.
After download completes , run the firmware update, that might solve your problem.I too have the same problem, then I updated my drive firmware and problem solved.
bajaj151 is offline
Old 17-06-2008, 07:57 PM   #12 (permalink)
bajaj151's Avatar
Default Re: Problem : Lite-On Disk Reading
New Problem: My DVD writer writes dvd smoothly but show error while while writhing CD....Burn Process Failed.
bajaj151 is offline
Lite-on DVD-ROM not reading NucleusKore Hardware Q&A 6 04-04-2007 12:42 AM
cd not reading gofeddy Software Q&A 4 25-11-2006 08:18 PM
CD-Rw is not reading brshravan Hardware Q&A 3 09-08-2006 10:33 AM
Cd Rom not reading disk ...need real help please Saharika QnA (read only) 1 26-10-2005 11:17 PM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
