29-11-2007, 05:07 PM
Speed for VOICE CHAT ?
How much speed is require for the clear voice chat using yahoo messenger ...?
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
29-11-2007, 05:44 PM
troubleshooter
Re: Speed for VOICE CHAT ?
It works even on 56 kbps connection
Better the connection speed faster
u will connect and chat !!
Go for broadband, dialup doesnt make sense these days
29-11-2007, 06:31 PM
Is Reliance data card with connection having 144kbps unlimited will do the job or should I go for another connection ?
29-11-2007, 06:40 PM
Rubik's Uncle!!
^^^ 144kbps is enough , but I doubts if you are getting full speed.
29-11-2007, 06:53 PM
Rebooting
For Voice chat its not speed rather its the stability of the connection is needed....
Cable Connection of LAN interface with 32 KBPS will performe better than CDMA 144 KBPS due to their flactuation of speed
thank you...
rebooting
ChotoCheeta.com
29-11-2007, 08:38 PM
thank you...
Ok...thanks...
29-11-2007, 08:47 PM
TechTin.com
128 Kbps is sufficient..but need stability.
29-11-2007, 08:53 PM
How can I check stability....or my headphone n mike ?
29-11-2007, 09:00 PM
TechTin.com
no dear..I mean stability in bandwidth.
29-11-2007, 09:02 PM
ok...but how can I check microphone and speaker ....?
I checked using call setup......they are working fine.
But is there any other way to check this.......???
I am getting this error : (Image)
29-11-2007, 09:06 PM
TechTin.com
The best way to check is do voice chating on yahoo messenger or Gtalk.Ask other person.."voice is clear or not"
29-11-2007, 09:08 PM
29-11-2007, 09:18 PM
We both r not getting clear voice .....
29-11-2007, 10:18 PM
TechTin.com
than either U are on slow connection OR your friend is on slow connection.
30-11-2007, 08:43 AM
I use Airtel GPRS over my Nokia 6630 in Mumbai. It has EDGE capability and i get decent speeds. Wud this be fine for a voice chat ???
30-11-2007, 10:03 AM
Rubik's Uncle!!
Whats the speed?
30-11-2007, 10:11 AM
TechTin.com
why don't you try a voice chat with ur friend..and find yourself.I think this is best way to go.
Search this Thread |
