Old 29-11-2007, 11:19 AM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question File Upload in Website using ASP or HTML or PHP
Hello Friends
I need to make a File Upload Section in Website
I need to make 1 Text Box (which days Description)
and one browse button (which browse the file)
and one Submite Button
when Someone Click submit button it will take some time to upload the file and after this it will give a Link to download that File
I searched google and Found
http://www.15seconds.com/issue/001003.htm
But not understanding how to setup this in Website because i dont know ASP
I have 2 sites with hosting from techiehost.org and host4cheap.org
Can anyone help ?
Or if any one has any simple file upload method than Pls tell
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 29-11-2007, 02:20 PM   #2 (permalink)
jaya's Avatar
Default Re: File Upload in Website using ASP or HTML or PHP
Example File Upload Form using php
A file upload screen can be built by creating a special form which looks something like this:
<form enctype="multipart/form-data" action="jaya_upload.php" method="POST">
<!-- MAX_FILE_SIZE must precede the file input field -->
<input type="hidden" name="MAX_FILE_SIZE" value="30000" />
<!-- Name of input element determines name in $_FILES array -->
Upload file: <input name="userfile" type="file" />
<input type="submit" value="Upload" />
</form>
jaya_upload.php code is
<?php
// In PHP versions earlier than 4.1.0, $HTTP_POST_FILES should be used instead
// of $_FILES.
$uploaddir = 'uploads/';
$uploadfile = $uploaddir . basename($_FILES['userfile']['name']);
echo '<pre>';
if (move_uploaded_file($_FILES['userfile']['tmp_name'], $uploadfile)) {
echo "File is valid, and was successfully uploaded.\n";
} else {
echo "Possible file upload attack!\n";
echo 'Here is some more debugging info:';
print_r($_FILES);
print "</pre>";
jayadev
jaya is offline
Old 29-11-2007, 06:45 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: File Upload in Website using ASP or HTML or PHP
Thanks Jay
Will try it and let u know
satyamy is offline
Old 29-11-2007, 06:49 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
with all do respect to jaya...
@satyamy
rather than custome script why dont you try a readmade free or paid script and modify it according to ur needs ???
http://www.hotscripts.com/PHP/Script...ems/index.html
rebooting
ChotoCheeta.com
Choto Cheeta is offline
where to upload my website anuragsedai QnA (read only) 5 23-11-2007 06:44 PM
How to upload website H.Lalnunmawia QnA (read only) 24 03-02-2007 11:12 AM
How to Upload RS file to FTP ?? hmmmmmmmmmmmmm QnA (read only) 1 26-11-2006 09:10 PM
want to upload 565 mb file ashishkamat QnA (read only) 15 05-03-2005 12:09 PM
