ok ... Got these from the NET.
Here are 3 options what you can try.
OPTION 1:
You can run SFC utility for checking system files corruption. You would be needing the XP cd if some system files are corrupt.
Run this in the command prompt.
sfc /scannow
For more information regarding SFC, click the link below:
http://www.updatexp.com/scannow-sfc.html
You can then try the normal routine for showing Protected/System files from Folder Options.
OPTION 2:
This is a Registry Modification hack. Backup your current registry before applying any of the following.
Backup Registry Help:
http://support.microsoft.com/kb/322756
Right Click the link below & save it. Double Click/Click the registry file. Press YES to continue addition to registry.
http://www.kellys-korner-xp.com/regs...vesettings.reg
Reboot & Check if it works now.
OPTION 3:
VB script file. Press Yes to execute the script.
http://www.kellys-korner-xp.com/regs...iddenfiles.vbs
Lemme know if any of them worked.
