Old 25-03-2005, 02:25 PM   #1 (permalink)
ClubHost.in
cancer10's Avatar
Default Setup Extractor
I want to extract the setup of a screensaver package I downloaded from www.freeze.com I don't want to install it because it has lots of adwares and trojans inside the setup file, I just want the .scr file and nothing else.
is there any way to extract a setup file?
PS: I have tried winrar but it cannot extract the setup file.
cancer10 is offline
Old 25-03-2005, 11:07 PM   #2 (permalink)
Fresh Stock Since 2005
If you have WinRAR installed, try right clicking it to see if it has a "Extract to........" Option. If it doesn't, i can't help...............
khattam_ is offline
Old 25-03-2005, 11:46 PM   #3 (permalink)
enoonmai's Avatar
Not all exe files are made with archivers. Some are made with custom packagers like InstallShield/Wise/Windows installer, and as such, extracting them would be pretty much out of the question. Usually the best way to extract such files is this: First, clean your temp folder (C:\Windows\temp for Windows 9x/Me, and %USERPROFILE%\Local Settings\Temp for Windows 2000/XP) and then delete ALL the files in that folder. Then click on the installation file, let it begin the installation and then the "extracting files" process. Do not proceed on the setup. Instead, go back into the temp directory and you should be able to find all the extracted files there. Copy the .scr file and delete the rest of the trojans and go back and cancel the installation and then delete the contents of the temp folder. Hope this helps a bit in your case.
Playing FEAR XP/LSW2
enoonmai is offline
Old 26-03-2005, 12:40 AM   #4 (permalink)
tuXian's Avatar
once I renamed the setup executable to .zip and was able to extract the files. I know it wont work always. Can someone explain this??
You know it's love when you memorize her IP to skip DNS overhead.
tuXian is offline
Old 26-03-2005, 12:53 AM   #5 (permalink)
That means it was compressed with a simple zip mechanism and with autoextractor and a custom icon.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 26-03-2005, 01:11 AM   #6 (permalink)
swatkat's Avatar
ZIP files can be made to Autoextract by making using the SFX provided by the Zipping Softwares.SFX stands for Self Extractor.
But every EXE file is not SFX file. For these file we have to execute/install them too see what contain!
http://swatrant.blogspot.com/
swatkat is offline
Old 26-03-2005, 09:45 AM   #7 (permalink)
ClubHost.in
cancer10's Avatar
ok dude, i will try that.
thanx
cancer10 is offline
Old 27-03-2005, 11:53 PM   #8 (permalink)
great trick enoo................
khattam_ is offline
Old 28-03-2005, 11:08 AM   #9 (permalink)
Some archives can be extracted directly without installing,this can be done by right clicking and then selecting Extract to......
Lovedeep Wadhwa
cheetah is offline
Old 29-03-2005, 12:17 AM   #10 (permalink)
For that you need a extractor like WinRAR installed.
Kannan.
Binary Bits
Kannan is offline
