Old 20-08-2004, 11:55 PM   #1 (permalink)
Default I can't play Fifa 2004.Please help.
I have a pentium 3 866mhz prcss,256mb sdram.My motherboard is Intel 815e,with 8mb on board video memory.Do i need a graphics card to play the game .What kind of graphics card should i buy. Please give me a suggestion.I was able to play fifa2003.
Becks is offline
Old 21-08-2004, 07:39 AM   #2 (permalink)
cooljeba's Avatar
welcome Becks to the forum.
There are several cards available m8 if u want a cheap one to play fifa 2003 u can opt Geforce4 MX 440 SE ( 64 -128 mb)
..:: peace ::..
Jeba
India's answer to Imageshack
cooljeba is offline
Old 21-08-2004, 08:49 AM   #3 (permalink)
You should be probably able to play fifa 2003 and before on that pc. Luckily, your motherboard will have an AGP slot, so you can upgrade to a better card. But dont go for an SE version (its a lower performer), instead, go for a normal GeforceMX 440 64 MB, should be bout 2.5k
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 21-08-2004, 12:20 PM   #4 (permalink)
welcome 2 this forum becks!
Running a game on onboard graphics card is stupid as the modern games r very demanding.Go in 4 a cheap solution by buying a GeForce MX 440 card...be warned though..it does not have pixel shader and texture shader support so some rare games wont run ex.
prince of persia:sands of time. Fifa series should run smoothly though on thiz card.
prankzter is offline
Old 24-08-2004, 05:10 PM   #5 (permalink)
pedal to metal
suave_guy's Avatar
You can also go for Geforce4 ti, its priced almost same as geforce4 MX and is somewhat better bet then geforce4 mx.
Enjoy!
your "attitude" is your best friend...
suave_guy is offline
