Old 22-11-2007, 04:23 PM   #1 (permalink)
Default Help me to copy cd & Dvd to Hdd
Hello Guys,
Help me to copy cd to Hdd, always it gets failed and says this
"cannot copy file name: Invalid MS-DOS function" Plz Guys help me fast i have to return Cd by tomorrow...
Regards,
Qadir
qadirahmed is offline
Old 22-11-2007, 06:15 PM   #2 (permalink)
Default Re: Help me to copy cd & Dvd to Hdd
[quote=qadirahmed]Hello Guys,
Regards,
Qadir[/quote
YOU CANNOT DESCRIBE THE PROPERTIES OF THE FILE. TRY TO OPEN THE FILE DIRECTLY FROM YOUR CD/DVD. IF ITS NOT OPEN THEN MAY BE THE FILE IS CORRUPT. PLEASE GIVE THE DETAILS OF THE FILE.
goldy_connect is offline
Old 22-11-2007, 06:22 PM   #3 (permalink)
vaibhavtek
Posts: n/a
it may be due to corruption or proction of CD.
Old 22-11-2007, 07:14 PM   #4 (permalink)
New
New's Avatar
Ya.. That cd is copy protected
New is offline
Old 22-11-2007, 07:23 PM   #5 (permalink)
Back in Power
almighty's Avatar
make image with nero or alcohal
and mount to use it
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 22-11-2007, 07:36 PM   #6 (permalink)
Pawned!... Beyond GODLIKE
fun2sh's Avatar
cd is corrupt dude
If God has indeed created Himself in His own image, then I submit to you that God is a cockroach :mrgreen:!!!!!!!!
fun2sh is offline
Old 22-11-2007, 07:37 PM   #7 (permalink)
vaibhavtek
Posts: n/a
then I think no way...
Old 22-11-2007, 08:47 PM   #8 (permalink)
left this forum longback
praka123's Avatar
u may try ur luck with some linux livecd and use "dd" command to create an image of the cd(whatever available).crc error means cd may be damaged.
praka123 is offline
Old 22-11-2007, 08:48 PM   #9 (permalink)
vaibhavtek
Posts: n/a
thats correct use the way and determines what had happen...
Old 22-11-2007, 11:12 PM   #10 (permalink)
No Guys cd was not corrupted its working fine in both my pc and vcd player....
its a video cd i mean .dat file and it was not write protect too.
coping file starts and gets failed after its 50% copied
Do help Guys
Old 22-11-2007, 11:16 PM   #11 (permalink)
Commander in Chief
QwertyManiac's Avatar
CRC issues. The Disc must be badly scratched. No go, forget copying it. Videos would play fine, as it happens at times (You don't see it skip frames). But copying will fail, always.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 23-11-2007, 12:26 AM   #12 (permalink)
No Dude it was just a Brand new cd i was the first one to break its seal.......
there may be any prob with my pc?
Old 23-11-2007, 12:30 AM   #13 (permalink)
Commander in Chief
Hmm, after Win 9x, MS-DOS copy errors are the same as CRC errors I guess. Try copying it with some other Optical Drive?
Harsh J
www.harshj.com
Old 23-11-2007, 12:35 AM   #14 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
brand new cds too can have crc errors dude.If you're on windows then you can use some bad cd recovery tool like iso buster(it aint free though but there are a lot of free alternatives as well) which replaces the unreadable data with garbage/0's and let you copy whatever is readable.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 23-11-2007, 12:40 AM   #15 (permalink)
yeah the sessions cant be read easily in video cds while copying
Try Isobuster
Its one damn rescuer and worked for damaged games cd too.
Faun is offline
Old 23-11-2007, 02:46 AM   #16 (permalink)
Back in Power
almighty's Avatar
make an image with alcohal
while making image choose an option "skip reading error"
alcohal make an image without those error,(skip)
try it... it worked for me all the time for video/audio cd/dvds
not recommended for any s/w or game
or another way is to convert it to mpeg with vcd cutter or any splitter and save as mpeg...
after changing and saving the format u can burn again with nero
almighty is offline
Old 23-11-2007, 06:28 AM   #17 (permalink)
vaibhavtek
Posts: n/a
try to copy using command dos.
Old 23-11-2007, 08:32 AM   #18 (permalink)
praka123's Avatar
this is what i used to have looong back:
http://www.jufsoft.com/badcopy/
http://www.jufsoft.com/badcopy/cd_recovery.asp
praka123 is offline
Old 23-11-2007, 12:13 PM   #19 (permalink)
vaibhavtek
Posts: n/a
ya that is good software.
forget to mention.
it will surely help.
Old 23-11-2007, 12:54 PM   #20 (permalink)
fun2sh's Avatar
ok so i got ur problem n here is the best solution.
USE THE GREAT SOFTWARE ISOBUSTER TO BUST ALL COPYIN ERRORS. it may take even a whole (i mean 24hrs) but ur cd will be copied n finally u can play those videos. TRUST ME I HAV USED THIS SOFTWARES N IT HAD NEVER FAILED ME. i hav copied many worse cds usin it. GIVE IT A TRY N IT WONT DISAPPOINT U.
HERES THE LINK
http://www.isobuster.com/
fun2sh is offline
Old 23-11-2007, 01:07 PM   #21 (permalink)
vaibhavtek
Posts: n/a
did u mean 24 hrs....
wondering....
Old 26-11-2007, 12:03 AM   #22 (permalink)
HERES THE LINK
it was sucked me.... i kept switch on my pc for nearly 30hrs..... (with monitor off) while it was completed upto 90% one of the fools has come and switched off my pc......
This is the only best way..... thx dude
Old 26-11-2007, 12:21 AM   #23 (permalink)
HERES THE LINK
Man i waited at most 30 mins and then if it didnt work then leave the CD in trash.
Most of the time it worked, better than alcohol or blindwrite
Faun is offline
Old 26-11-2007, 12:46 PM   #24 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
do whot @almighty has posted .....
u can watch the movie as if u have popped in cd\dvd in ur drive ......
its great .........
... W H O T ...
ax3 is offline
Old 26-11-2007, 02:15 PM   #25 (permalink)
fun2sh's Avatar
isobuster has always worked for me. its a lifesaver!!!
fun2sh is offline
copy dvd to hdd vicky_l7 QnA (read only) 4 21-06-2007 02:13 PM
how to copy Dvd to Hdd kjuvale QnA (read only) 6 17-06-2007 12:15 PM
TOTAL COPY-Copy Stuff In A diff Way! rakeshishere QnA (read only) 17 28-02-2007 09:39 PM
Copy DVD royal QnA (read only) 11 04-12-2006 12:25 PM
how 2 copy? bharathbala2003 QnA (read only) 23 15-03-2005 11:21 AM
