Old 24-03-2005, 11:25 PM   #1 (permalink)
Default Any HP Pavilion Users Here??
Iam using an HP pavilion t560i. Initially when i bought it, it had 2 partitions on the same hard disk (80 GB), one for recovery ( 4GB) and the other is the user partition(74 GB). I had resized the user partition and created another partition of 15 GB. For the past few days i have been unable to download anything from the internet, probably because of a virus (whic i couldn't find using norton 2004). I then reinstalled XP but that didn't help either. Now i want to use the destructive revovery partition which says that "all data on the USER PARTITION will be deleted and the USER PARTITION will be reformatted". Will this delete the partition created by me (15gb) also?? can't i use it for backing up my data(which is quite a bit)??
sahil_blues is offline
Old 25-03-2005, 10:30 AM   #2 (permalink)
enoonmai's Avatar
Well, I dont have a Pavilion but I have a Brio and I guessing all HP computers and their recovery discs will behave in the same way. So, if you were to use the Recovery method that HP recommends and provides for, then yes, it will delete everything on your HDD and reset everything to the factory defaults. All of your data would be lost, if the Pavilion behaves like the Brio. Your safest bet would be to disconnect the hard disk, take it to a friend's place and offload it to either his hard disk or a DVD+RW (that is, if your computer didn't come with one) and then use the tool on your computer to reset the computer to the factory defaults and then recopy all your data back to it. (I don't suppose they still provide a separate Windows XP disc, do they? Its all bundled in the same recovery tool, isn't it?)
Anyway, before you take drastic measures, do explain the problem in detail and what happens when you try to download something from the Internet. Do you get an error, data corruption, etc. Also, please download HijackThis from here, run it and paste the log file it creates back here in this thread, so we can take a look it spyware/viruses are indeed causing this problem. You can download HJT here:
http://www.spywareinfo.com/~merijn/downloads.html
Also, please refer this excellent tutorial on using HJT, if you're ever unsure of as to what to do:
http://www.thinkdigit.com/forum/viewtopic.php?t=15729
Playing FEAR XP/LSW2
enoonmai is offline
