24-03-2005, 11:19 PM
Video Editing !!!!! Which Better
AMD or Intel
which one shud i go 4
AMD 64 3000+
intel 3.2 ghz
25-03-2005, 12:00 AM
Intel, still pawns AMD when it comes to Video encoding, also make sure U get atleast 1.5 GB RAM, if using premiere
25-03-2005, 12:02 AM
If it's Video editing, go for Intel.
http://swatrant.blogspot.com/
25-03-2005, 12:08 AM
Dude one word of advice. Put in as much RAM as you can afford. I say atleast 512 MB. Don't neglect the RAM. It can prove to be a bottleneck for your processor, if you don't have enough RAM.
SportZForumZ - We Know Your Game Better
http://www.sportzforumz.com
My Site & Blog
http://www.rohit-sharma.com
25-03-2005, 01:39 AM
I have never seen ram usage of over 512 in my PC , which includes Video Ripping , Mpeg4 to mpeg 2 etc .
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
25-03-2005, 02:30 AM
@indro I have been using Adobe Premier for some time now. Believe me u need a decent PC with enough RAM to apply the video effects quickly, or it will take lot of time to apply some effects on a full length movie. You might not be facing such problems because you are having a graphics card and it has some RAM of its own.
My Site & Blog
25-03-2005, 09:54 AM
For Gaming go for AMD for shure but if If it's Video editing, etc. then go for Intel.
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
25-03-2005, 10:13 AM
I have been using Premiere Pro & After effects from the last 4 months, & belive me it is heavy on RAM, importing a 690 MB DivX was not posible before, but now I incresed my pagefile to 2 GB, atleast it is working but slow
1.5 GB RAM is absolute minimum if U R into heavy video editiing, like pro guys, if U R simply for home then even 256 MB is enough
25-03-2005, 10:18 AM
Hey dude I think 2 GB of pagefile is far much more than enough !!!
I dont think so much pagefile is needed !!!
25-03-2005, 11:03 AM
@rachitboom2: You've obviously never worked with Adobe Premiere then. That is one software that needs heavy duty CPUs, oodles (read GBs) of high speed RAM, a really fast hard disk, and tons of virtual memory to work the way its supposed to work.
@plsoft: Everyone is right. Video encoding is the last thing in which Intel hasn't succumbed to the AMD64s. But remember that you need a lot of RAM and quite a good video card if you dont want to spend too much time watching the export process. Without at least 1GB of low-latency RAM, be prepared to spend hours doing something else while Premiere works at exporting an 1 hour movie.
Playing FEAR XP/LSW2
25-03-2005, 05:18 PM
Hey I have used Adobe Premiere, but I havent had any problem yet of low RAM as I already have 768 MB RAM (3 * 256) and 1024 MB of pagefile !!!
28-03-2005, 09:43 AM
I've been using Premiere for quite a time now. Well most of you guys hit the spot. Premiere needs RAM and a lot of it. I have this 3 GHz P4 system with 2GB DDR 400 and still some effects render slowly. But for home videos and the like 768 would be more than enough. And yea Intels are definitely geared towards Video Encoding esp. with the inclusion of Hyperthreading and the huge cache.
P4 3.2 GHZ + 512MB X 2 KINGSTON DDR 400 RAM + INTEL 915 MOBO + 2 X 120 GB SAMSUNG SATA IN RAID-0 + AUDIGY 2 ZS+ GAINWARD 6600 GT + WIN XP SP2 + SUSE 9.2 PRO + UBUNTU 5.04
28-03-2005, 10:48 AM
2 GB Page file, I know it's more then required but I m staying on a safe side
for light home video editing, Windows Movie Maker is even enough, with 256 MB RAM
The speed at which Premeiere applies filters is not RAM dependent, but CPU & effect dependent, the motion effect is applied fast as it has less work to do while the Keying & Matte are slow, as there is lot of calculation, upgrading your RAM or CPU won't give U much of the performance increse
ennonmai
exporting a Movie with premiere is compleately CPU bound, get a Dual CPU system & see the difference, the WMV 9 codec takes very much time, best codec I have found is DivX 5.21 with 4 mb bitrate & the required resolution
Search this Thread |
