Old 20-08-2004, 07:26 PM   #1 (permalink)
Default CD-RW Usage
Hey ppl
I need to know the most advisable way of using and re-using a CD-RW as many get curropted after 2-3 uses..
I mean which software is good for formatting/reformatting and usage and if any tips-tricks are available for it ?
I\'M BACK
khandu is offline
Old 20-08-2004, 07:37 PM   #2 (permalink)
well, u can put any softwarez on the disk but if itz longetivity u r searching, then go in 4 a good cd-rw like mosaer baer etc.I am using mosaer baer cd-rw 4 the 10th time now...after writing this post and it runs P E R F E C T L Y!
prankzter is offline
Old 20-08-2004, 08:25 PM   #3 (permalink)
Hmm.. trying a SONY CD-RW + InCD ... lets c its life...
I\'M BACK
khandu is offline
Old 20-08-2004, 10:59 PM   #4 (permalink)
I use the latest 10x compatible Moser Baer CD-RW...I have re-written about 18 times till now...still works perfectly.
The longitivity of the CDs depend on the way u handle it & not on the software u use to burn or to erase it.
sUlPhUr|nE` is offline
Old 20-08-2004, 11:02 PM   #5 (permalink)
I have sony, samsung & moser beur(not sure about the spelling) & have written & rewritten over 50 times now. No problems yet. I think you can rewrite for 1000 times or so.
siddhesh is offline
Old 20-08-2004, 11:13 PM   #6 (permalink)
i dont think there is any specific brand which u can say is the best, though i use sony or samsung. i think that for best performance u need to fill up the cd before emptying it, and try to perform quick erasing with nero. i have rewritten around 70 times on my sony and it still runs fine.
technomodel is offline
Old 21-08-2004, 12:08 AM   #7 (permalink)
IG
i'm using an ancient hp 4x and about 30 times.....not had problems yet...
IG is offline
Old 21-08-2004, 12:36 AM   #8 (permalink)
Hmm.. fully formatted a 650 MB sony CD-RW .. says capacity only of 550.. Hmm...
I\'M BACK
khandu is offline
Old 21-08-2004, 09:24 AM   #9 (permalink)
First thing. Never Full Format the CD-RW regularly. Use only quick format.
Second thing. Specially for CD-RW, Burn the CD-RW slower than what its maximum is specified.
For Example, if you have a 10x CD-RW, always burn it at 8x. But dont touch the 10x speed.
In our office we use Nero 6 & Adaptec Easy CD Creator.
Both are fine and work perfectly.
I have been using Samsung, TDK. Had no problems with them.
Also finally keep your CD-RW's data side scratchless. Otherwise the writer will says that burning of CD-RW was sucessfull. But sometimes with certain CD-ROM drives you can't read it.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 21-08-2004, 09:43 AM   #10 (permalink)
Use Samsung its quite good even at 10x have used it about 35 times already still working perfectly fine
PIII 550 MHz 128 MB RAM GeForce 2 MX 400
.:pEaCe:.
Join this cool forum!
www.tech-station.net
Loki87 is offline
Old 21-08-2004, 11:41 AM   #11 (permalink)
busyanuj's Avatar
Samsung 10x RW media is working fine for me.
I must've used it over 100 times or so.
as for the software, use InCD 4.
busyanuj is offline
Old 21-08-2004, 12:02 PM   #12 (permalink)
I use LG 52x RW with INCd 4..and it works perfectly like i said for the 10 times already now.
Old 21-08-2004, 12:05 PM   #13 (permalink)
GameAddict's Avatar
Default Yes! Moser Baer is simply fantastic!
I agree with all those who say that MB is good. Moser Baer gives best price/performance ratio.
GameAddict is offline
Old 21-08-2004, 01:05 PM   #14 (permalink)
Moser baer, sony, samsung and HP all are good brands. If u use the cd-rw properly only then u will b able to enhance its longevity. Most of our cd-rws get crapped due to scratches. So prevent those in the first place.
@gameaddict: U never thanked me for resizing and putting up your avatar or did i miss sumthng?
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 22-08-2004, 04:19 PM   #15 (permalink)
does water affects cd-r and cd-rw's??
i mean if there's some dust on the writable layer and i wipe it off with
a cotton bud soaked in water,will the cd-r, rw get affected!!
and what is the cd material made up of??
We are what and where we are because we have first imagined it...
--Donald Curtis
silly_kash is offline
Old 23-08-2004, 12:42 AM   #16 (permalink)
Not So Fresh Stock!
There is no way plain water can harm it. For care about CDs you can see this link:
For one page guide:
http://www.itl.nist.gov/div895/carefordisc/onepage.pdf
For fifty page guide:
http://www.itl.nist.gov/div895/caref...dlingGuide.pdf
CDs are generally made of Polymers and lot of other materials. You need to confirm this.
http://krishanu.in
Krishanu.De is offline
Old 23-08-2004, 08:55 AM   #17 (permalink)
No I dont think so. I have wiped my CD-RW with water 2 times. Still it works fine.
Kannan.
Binary Bits
Kannan is offline
Old 23-08-2004, 09:53 AM   #18 (permalink)
hmm!!
good links krishanu.de
again there are many cases which i have come across in which cd-r's develop numerous stains(patches on it)and render it useless.
most of the princo cd's i have go bust like this!!(after a year or so)
maybe the result of using cheap cd's.
has anyone else expirienced similar problem's with princo cd-r's??
--Donald Curtis
Old 23-08-2004, 06:10 PM   #19 (permalink)
Princo uses a very cheap dye for its cd-r,rw's; worst compant to get a cd-r from !
