Old 20-11-2007, 06:02 AM   #1 (permalink)
Think Well Before You Do
thinker's Avatar
Unhappy please help me out with this problem????
I think it's fairly simple, but for some reason I can't find the answer.
I want to write to a file, in a certain format; however, it doesn't write it exactly as I want:
C Syntax (Toggle Plain Text)
1. fprintf(fpout, "ATOM %2d %c %c %d %02.3f %02.3f %02.3f\n", i, 'C', 'C', 1, *(x+i), *(y+i), *(z+i));
2.
This produces something like this:
ATOM 6 C C 1 5.047 5.964 17.520
ATOM 7 C C 1 10.631 18.405 10.309
ATOM 8 C C 1 16.209 3.768 17.726
ATOM 9 C C 1 11.412 1.535 16.305
ATOM 10 C C 1 19.698 2.367 17.878
ATOM 11 C C 1 15.690 2.018 5.066
(in the text file everything is in OK up to the 1).
However, as you can see, the coordinates (the last 3 floats).
because some numbers are in 2.3f format, and others in 1.3f format, they don't line up as i want. I tried using "%02.3f" so that it embeds a 0 in front of the coordinate IF the coordinate is in 1.3f format. (Still with me? ). But that doesn't work; the 0 isn't put in the file.
For some reason it does work with the %2d in the 2nd column.
Any ideas?
thinker is offline
Old 20-11-2007, 05:29 PM   #2 (permalink)
hansraj's Avatar
Default Re: please help me out with this problem????
man u r probably dealing with something too fundoo..... i cant make out a single line of u r post except the last one. hope u find some good geek around
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 20-11-2007, 10:10 PM   #3 (permalink)
Pawned!... Beyond GODLIKE
fun2sh's Avatar
wil u put ur complete program here???
n there is a seperate programin section for all these
If God has indeed created Himself in His own image, then I submit to you that God is a cockroach :mrgreen:!!!!!!!!
fun2sh is offline
Old 20-11-2007, 10:48 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try this example. I had to remove the pre-decimal specifier, so that the printf obeys the width set, dunno why it didn't though, when coupled with that specifier.
#include<stdio.h>
int main()
    int i;
    float a[4]={5.123,10.444,16.555,11.777},b[4]={6.321,7.432,8.654,18.987},c[4]={13.124,7.442,19.201,4.666};
    for(i=0;i<4;i++)
    printf("ATOM %02d %c %c %d %06.3f %06.3f %06.3f\n", i, 'C', 'C', 1, a[i], b[i], c[i]);
Outputs as:
ATOM 00 C C 1 05.123 06.321 13.124
ATOM 01 C C 1 10.444 07.432 07.442
ATOM 02 C C 1 16.555 08.654 19.201
ATOM 03 C C 1 11.777 18.987 04.666
There you go, all are lined up evenly.
I think using C++ would be better for formatting your outputs the easy way. Why choose C?
Harsh J
www.harshj.com
QwertyManiac is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
