Old 19-11-2007, 04:45 PM   #1 (permalink)
Deadman Walking
Batistabomb's Avatar
Default How to remove autorun pop-up
whenever i am right clicking the c: or d: or e: , instead of "open" in first drop - down tab, a new tab "autorun" is appearing so whenever i double click a new window will certailnly open,i think all are awareof this win32 tr worm spread with usb,i cleaned it but the mistake i done during cleaning is that i deleted the corresponding key in registry instead of repairing,so now whenever i was double clicking drives it was saying copy.exe is missed i;e; i want this auto run to disable in the drop down menu and my drives should certainly open double click
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 19-11-2007, 05:02 PM   #2 (permalink)
-----ATi-----
nvidia's Avatar
Default Re: How to remove autorun pop-up
You delete the autorun.inf file in the drives.
http://twitter.com/akshayms
nvidia is offline
Old 19-11-2007, 05:05 PM   #3 (permalink)
Deadman Walking
nothing like that inside the drive even in hidden files also
Learn to live... &
Live to learn...
Old 19-11-2007, 05:06 PM   #4 (permalink)
-----ATi-----
nvidia's Avatar
Under folder options there will be an option "Hide Protected OS files" Uncheck it.
You should be able to see that file...
nvidia is offline
Old 19-11-2007, 05:10 PM   #5 (permalink)
Deadman Walking
dude i removed those all the 3 tick marks but not such type of file
Learn to live... &
Live to learn...
Old 19-11-2007, 05:22 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
In folder option check "hidden files and folder"
ravi_9793 is offline
Old 19-11-2007, 05:23 PM   #7 (permalink)
-----ATi-----
nvidia's Avatar
oh.. then it must be some other kind of virus... Not the one that was there in my system.. But it showed the same signs...like opening in a new window etc..
did you see if it was there in any other drive?
nvidia is offline
Old 19-11-2007, 05:28 PM   #8 (permalink)
Deadman Walking
don't fear this is not a virus just an usb worm
Learn to live... &
Live to learn...
autorun Tushar.bar QnA (read only) 3 28-01-2007 12:57 PM
cd can't autorun in xp vraj_shani QnA (read only) 4 11-05-2005 11:57 PM
Autorun Gone... CD sourav QnA (read only) 5 02-05-2005 10:29 AM
Autorun Cd`s ax3 QnA (read only) 3 26-01-2005 09:07 AM
Autorun deepakuma QnA (read only) 7 25-11-2004 12:27 PM
