Originally Posted by bharathbala2003
dude, he has already downloaded a converter...why dont u do a bit of reading?
Originally Posted by anand20383
i tried to convert these files to mp3 ,they converted to mp3 and when i burned those songs in on cinverting them to .cda format i.e., i burned them in audio file mode in nero . when im playing them in my cd player i can clearly hear some noise and distortions. please show me a way to clear this distortions .if please list some good softwares in the reply.
do the converted songs give any distortion? if so, then its probably coz the songs u dloaded might be encoded in low quality real format. but try this:
u can either use the converter that u presently have, or u can use
dbpoweramp music converter.
download and install dbpoweramp:
http://www.dbpoweramp.com/bin/dMC-r11.exe
and then download and install the real format decoder:
http://www.dbpoweramp.com/codecs/dBp...P-codec-ra.exe
now while encoding into mp3, try setting the bitrate a bit high (192 kbps or more) and set the frequency at 44 kHz or higher.
now, if that doesnt solve ur problem, then u may have to opt for some sound editing software like adobe audition or sony soundforge or audacity to clear the distortions. (sorry, but i cant guide u here, coz i havent done something like that myself... some1 else with better knowledge may be able to help)
also, if ur original songs didnt have any distortions, but gives distortions after burning, then maybe it cud be due to write error.
hope this helps
