Old 18-11-2007, 01:32 AM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default HD to normal
i have loads of images taken from a new sony dsc t-200 which takes full hd stills at 1920x1080 but i wanna convert them to 1280x1024 - is it possible?
http://beingmanan.com
iMav is offline
Old 18-11-2007, 10:56 AM   #2 (permalink)
www.VideoEditingIndia.com
VideoEditingIndia's Avatar
Default Re: HD to normal
Yes, Even Microsoft Office Picture Maker will do this.
TATASafariClub.com - Its only for MEN - News, Tips, Photos & Guidelines for Men!
VideoEditingIndia.com - Film, Audio, Video Editing & Compositing - Get movie Night Right!
VideoEditingIndia is offline
Old 18-11-2007, 11:19 AM   #3 (permalink)
Web developer
narangz's Avatar
May I suggest IrfanView? In the image resize option select resampling.
narangz is offline
Old 18-11-2007, 12:31 PM   #4 (permalink)
Jai Suresh
lywyre's Avatar
I second that. You can create a batch operation for multiple images.
lywyre is offline
Old 18-11-2007, 12:34 PM   #5 (permalink)
iMav's Avatar
didnt work it squeezes the images
iMav is offline
Old 18-11-2007, 01:35 PM   #6 (permalink)
Web developer
narangz's Avatar
^^select preserve aspect ratio
narangz is offline
Old 18-11-2007, 01:48 PM   #7 (permalink)
iMav's Avatar
a wide screen wont become a normal image .... i tried it .... even if u select a certain size it will on its on re-size it to a widescreen resolution
for eg: if u take a wide screen image and choose 1600x1200 it will zabardasti make it 1600x900
iMav is offline
Old 18-11-2007, 01:52 PM   #8 (permalink)
Web developer
narangz's Avatar
can i see one of those hd pics? i mean a pic which has no personal 'content'
narangz is offline
Old 18-11-2007, 01:54 PM   #9 (permalink)
"The Gentleman"
vish786's Avatar
its necessary to maintain an aspect ratio(appr. pixel x pixel size) or else image looks squeezed from one end. u'll have to try trial & error for resizin, using a good image editor.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 18-11-2007, 01:58 PM   #10 (permalink)
iMav's Avatar
iMav is offline
Old 18-11-2007, 02:01 PM   #11 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
You need to correctly Crop it!
First Reduce the Height to 1024 by keeping the Ratio Constant, Now Crop the sides till 1280 pixels.
Easier in Photoshop, Reduce the Image Size, Reduce the Canvas Size.
No other way. (other than adding black bars on top or bottom)
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 18-11-2007, 02:04 PM   #12 (permalink)
iMav's Avatar
i dont wanna crop it .... if i wanted to crop theres a simpler way just reduce the canvas size
iMav is offline
Old 18-11-2007, 02:05 PM   #13 (permalink)
Web developer
narangz's Avatar
Cropping & Resizing are different things.
@Manan- I'll try resizing it. Is it diwali pic?
narangz is offline
Old 18-11-2007, 02:15 PM   #14 (permalink)
iMav's Avatar
no not diwali .... took this is in goa day b4 yesterday its actually a bridge and a cruise boat with lights
iMav is offline
Old 18-11-2007, 09:18 PM   #15 (permalink)
Web developer
narangz's Avatar
yeah i tried yaar. if we preserve the aspect ratio then its still widescreen otherwise its sort of squeezed any specific reason for not not liking the widescreen resolution?
narangz is offline
Old 18-11-2007, 09:19 PM   #16 (permalink)
iMav's Avatar
well my desktop is not widescreen thanx for trying .... appreciate it
iMav is offline
Old 18-11-2007, 09:25 PM   #17 (permalink)
Web developer
narangz's Avatar
you are welcome buddy... i m on a lookout for a solution if there is any.
narangz is offline
Old 18-11-2007, 09:37 PM   #18 (permalink)
iMav's Avatar
widey sir no letterboxing or cropping
iMav is offline
Old 18-11-2007, 10:36 PM   #19 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: HD to normal
just simply resizing to 1280x1024 will not give smooth image imav.... you 'll have to ReAspect(stretching top,bottom, left, right or stretch an unimportant portion of image).
- Dijkstra
vish786 is offline
Old 18-11-2007, 10:55 PM   #20 (permalink)
iMav's Avatar
that was the reason i asked
iMav is offline
Old 19-11-2007, 12:18 AM   #21 (permalink)
 Macboy
goobimama's Avatar
You were in Goa and you didn't tell me? Kya yaar. Anyway, you will have to crop the image to make it 4:3
I'm like a bird... :)
goobimama is offline
Old 19-11-2007, 12:20 AM   #22 (permalink)
iMav's Avatar
i was banned and pc was dead so had no net conx
http://www.thinkdigit.com/forum/show...&postcount=299 - some pix i took
iMav is offline
is this Normal? Raaza QnA (read only) 2 17-05-2007 05:54 PM
Tell the normal temperatures codename_romeo Hardware Q&A 3 15-11-2006 11:14 AM
Are these temps normal??? varkey Hardware Q&A 6 11-11-2006 11:26 AM
Is this normal speed? vasulic QnA (read only) 15 11-08-2006 10:36 PM
is this file normal or no hack expert QnA (read only) 2 18-07-2005 03:45 PM
