Old 17-11-2007, 10:58 PM   #1 (permalink)
Web developer
narangz's Avatar
Angry Restore without Restore Discs?
Hey friends!
My question is how can I install Windows on my Compaq laptop without restore discs? I mean I do not want to delete partitions, data. The restore discs will delete them. I want to know can I install from Vista Disc & use my key? If yes from where can I obtain the Vista Installation Disc?
narangz is offline
Old 17-11-2007, 11:25 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: Restore without Restore Discs?
if you install thru othr Vista disk, then you'll have to Install the drivers yourself (d/l frm hp website).
read the laptop's manual, there shud be a "Standard Recovery" which restores the OS from HDD (no formatting/deletion takes place)
check whether you have a separate partition, called Recovery Partition.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 17-11-2007, 11:30 PM   #3 (permalink)
Web developer
narangz's Avatar
Yes I have recovery partition. But I want the solution for clean install.
narangz is offline
Old 17-11-2007, 11:32 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
then, d/l all the drivers frm hp's wbsite.
but one more thing, your current Vista key is OEM key, so it might not work/get validated on the other version.
get it clarified & then only proceed.
Old 17-11-2007, 11:39 PM   #5 (permalink)
Web developer
narangz's Avatar
I have the drivers. What I wanted to know is which Vista DVD will help me out of my problem & will accept OEM key.
I know a method by using Windows Vista Anytime Upgrade Disc, but those discs are not available in India! Help me guys!
narangz is offline
Old 17-11-2007, 11:41 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
It was not possible with XP. The OEM key wouldn't work with a retail copy. However from what I've heard, its possible in Vista. I do not use an OEM Vista. So wait for someone else to give in his/her views.
infra_red_dude is offline
Old 18-11-2007, 12:26 AM   #7 (permalink)
Rubik's Uncle!!
Charan's Avatar
@narangz: PM sent .. please check your inbox
Charan is offline
Old 18-11-2007, 11:06 AM   #8 (permalink)
Web developer
narangz's Avatar
^^ Thanks buddy! Check your inbox
narangz is offline
Old 18-11-2007, 12:31 PM   #9 (permalink)
Wire muncher!
I believe it can be done in Vista coz I remember iMav saying that he'd installed a retail copy of Vista on his laptop with the OEM key. Contact him for further details, narangz.
PS: Is your name/surname Narang or are you a fan of Don??
Old 18-11-2007, 12:47 PM   #10 (permalink)
Web developer
narangz's Avatar
Surname is Narang. I haven't seen Don
Thank you for the suggestion!
@ Charan- Painful avatar. Ouch! It hurts!
narangz is offline
Old 18-11-2007, 12:47 PM   #11 (permalink)
The Devil's Advocate
iMav's Avatar
i installed vista from the dvd i had previously and used my hp windows key it worked for me
http://beingmanan.com
iMav is offline
Old 18-11-2007, 01:37 PM   #12 (permalink)
Web developer
narangz's Avatar
^^ Okay. Thank You. But obtaining a dvd is a problem. Most of the downloads available are pre-activated/cracked/hacked.
narangz is offline
System Restore Goes Away.... dinesh_mettur Software Q&A 1 19-11-2006 11:47 AM
pls help restore my icon sysfilez Software Q&A 6 03-11-2006 12:02 PM
Cant restore system using 'System Restore' Swappy Software Q&A 4 23-08-2006 10:33 AM
system restore....????? john_the_ultimate QnA (read only) 9 11-08-2005 03:41 PM
System restore mako_123 QnA (read only) 3 06-05-2005 02:43 PM
