Old 17-11-2007, 12:40 PM   #1 (permalink)
Question Unknown Add/Remove Program
I have seen on add/remove program on Winxp, that my add/remove program contain 4-5 unknown software which i not installed at this time, yes i agree that i have installed these software on previous time, but i format the whole disk and installed a fresh copy of WinXP.
But these software is still was there. If i try to remove from add/remove they give the error "Please insert a disk to uninstall these program", but i don't have a disk righnow. How should i remove these program from add/remove, there is any way to remove it.
Please check the screenshot. Top one is Alcohol that the name was not appear.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 17-11-2007, 12:51 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: Unknown Add/Remove Program
Do ur XP install cd is a modded one. I mean is it created with some softwares that can add additional softwares in the Base XP CD image like BartPE etc. ?
If that is true then u have to install it from a original XP CD (no piracy here ) to avoid installing those extra stuffs.
debsuvra is offline
Old 17-11-2007, 01:39 PM   #3 (permalink)
WHAT , i am using Genuine software. I have install these software on feburary but after September i have format a partition and install a new software, but when i see a add/remove those previous software was still there. There is any registry key was still alive.
boosters is offline
Old 17-11-2007, 03:06 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Did you do a fresh installtion with format.I am surprised, that after reinstall, there are some software in your add or remove list.
ravi_9793 is offline
Old 17-11-2007, 03:16 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Open regedit and goto:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
Under this key, you'll get several other keys. Each key represents a software entry which you see in Add/Remove programs list. So delete any key which you want to not show in list.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 17-11-2007, 03:22 PM   #6 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Another (easier) method to perform the same above is to use CCleaner!
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
plz remove error in my c program arunks QnA (read only) 2 22-08-2007 08:19 PM
remove startup program anu0512 Software Q&A 5 08-11-2006 02:33 PM
Disable add/remove program linardni QnA (read only) 6 06-11-2006 03:43 PM
new program in 'close program menu' list and more....... vishakadatta QnA (read only) 2 12-04-2005 11:33 PM
